Flood Damaged Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 04:48 AM   #1
Rewards Points: 22
flood damaged boiler
I inherited a house from my mother. It has been vacant for a year. Being vacant, I couldn't get normal insurance. Hurricane Irene flooded the basement. The boiler, was completely submerged.
It is a relatively new (5 years) oil fired steam Slantfin boilerI
I was just notified that FEMA will not pay anything either.
Must the boiler be replaced or can I get new insulated panels, a new combustion chamber refractory, a new burner?
I know the parts are expensive, but it has to be a savings.
chuck172 is offline   Reply With Quote
Old 09-06-2011, 05:32 AM   #2
An old Tradesmen
Rewards Points: 6,464
You can get all the parts replaced. Won't be cheap, but a bit less then a new boiler.
Old 09-06-2011, 04:15 PM   #3
REP
It might not be as bad as you think.You will not need a new burner.Maybe just a relay or a transformer.
If it was a brick or ceramic combustion chamber then you probably won't need new there either.
As far as anything else,anything that had live electric to it when it went under water will need to be inspected and maybe replaced.
What you need is a trust worthy service guy to clean and check boiler and do a instramental set up.
Repair will be a lot cheaper then replacement by far.
REP is offline   Reply With Quote
Raw edges on flood damaged drywall joelle Drywall & Plaster 3 08-22-2011 05:18 PM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Replacing flood damaged furnace/ac cebeling HVAC 1 07-08-2009 08:35 PM
