Flexible Duct In Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 05:58 PM   #1
A.FC
Flexible Duct in Attic
I'm curious if anyone out there knows anything about flexible air ducts for heating and cooling? I currently have uninsulated ducts running through my attic and looking to replace it. Is there a type of flexible duct preferred? Once installed is it hard to maintain? Are there any condensation concerns with the insulated type?
Any ideas?
- First Time Homebuyer.
Arsenal is offline   Reply With Quote
Old 11-16-2009, 08:45 PM   #2
An old Tradesmen
Rewards Points: 6,538
If you have A/C ducts in your attic. They are insulated. Or you would have condensate on your ceiling.
Any approved flex duct is fine. Installed properly, there is no maintainence to do to them.
Old 11-16-2009, 09:48 PM   #3
Household Handyman
Rewards Points: 1,408
"Arsenal", what makes you think you're ductwork is not insulated? David
Old 11-17-2009, 09:55 PM   #4
A.FC
"beenthere" thanks! The prior owners looked like they may have only changed the furnace filter once a year. The filter was black when i changed it my first month. It was so bad that the HVAC guy had to clean the motor and blower housing. Can the flexible ducts be cleaned?
Old 11-17-2009, 10:16 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Arsenal View Post
Are there any condensation concerns with the insulated type?....
There are condensation concerns with the NON-insulated type.
On a recent TOH the homeowner complained that during the winter his upstairs bathroom fan vent would drip water, even before anyone used the shower.
Tommy solved his problem by replacing the non-insulated 4" flexible fan duct with flexible insulated duct
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-17-2009, 10:36 PM   #6
An old Tradesmen
Flex can't be cleaned without risking damaging it.
Old 11-18-2009, 05:54 PM   #7
Filter
Keep changing the filter every chance you get eventually it should be cleaner than before.
Some people never change the filter or even know there's a
filter in there.
Recomendation: R-8 flexible duct if you are changing out the existing.
SULTINI is offline   Reply With Quote
Old 11-18-2009, 06:16 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
If it ain't broke don't be fixin it or touchin it some people think.
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 06:46 PM
Install HRV duct in attic? dalyman0 HVAC 1 10-21-2008 08:47 PM
flexible duct bingo HVAC 1 09-13-2007 10:54 PM
New flexible air duct co20070904 HVAC 3 09-05-2007 10:32 AM
