Old 06-10-2008, 03:46 PM   #1
Default Flexible copper or Rigid Copper for solar?
I was recommended to post this in this forum from the plumbing.
I'm connecting solar panels, running glycol (closed loop). The loop has to be copper as the panels & fluid can reach up to 300F in the unlikely event there's a power failure at sunny noon time. If power comes back the system will kick on sending up to 300F fluid through the lines. Pex is out. I can't find anything if flexible copper would be okay or not, it would be a heck of a lot easier to run it in the attic than soldering stretches of rigid pipe and glycol is thinner than water and will leak in places water will not so the fewer joints likely the better. Know if there's any downfall to flexible copper?
Piedmont is offline   Reply With Quote
Old 06-10-2008, 05:04 PM   #2
I would use either low temp. silver solder or flexable and compression fittings. Both will be expensive.
Good luck.
BillyD is offline   Reply With Quote
Old 06-10-2008, 05:11 PM   #3
Sorry I forgot flare fittings.
Old 06-10-2008, 06:26 PM   #4
Thanks, I'm set with the solder my instructions tell me which to use (regular and not silver, 95/5, nor brazing) and no compression/threaded fittings if at all possible. Can't say I've heard of low temp silver or even know what "regular" solder is! I have to solder to about a 1" length rigid copper pipe sticking out of a gasket, takes the right skill & solder to get a good joint without damaging the gasket.
See any downfall using flexible copper to go to/from the panels? I'd like to use it instead of a bunch of rigid pipes, but have only used rigid all my life and don't know if flexible copper can handle the temps or reliable as rigid. Thanks!
Old 06-11-2008, 10:56 AM   #5
I've used standard 15mm copper with compression fittings to run the solar loop and it worked fine (using Loctite 577 for the problem points).
I know other solar systems guys use flexy stainless steel pipes which are much easier to handle (being flexy), but also are more expensive.
Technion is offline   Reply With Quote
Old 06-11-2008, 11:47 PM   #6
i recently had a solor rep at the hvac service company i work at and he specificly recomended lineset remember plumbers order inside we order outside ther 3/4 is our7/8
geo fan is offline   Reply With Quote
More On This Topic
What you see here is a solar water heater. So totally different to photovoltaic or to solar electricity. This one is just using the sun to heat up water. And when you look close, I opened it up for you that you can see what's going on there. In here is... Read More »
Now when picking out footwear, one of the decisions you are going to have to make is whether to go with a shoe or a boot. And most people think that the obvious answer would be a boot. But not necessarily. This boot just happens to be the most popular at... Read More »
Tres Tew here, I'm an instructor at Yshua's Ryu Martial Arts and on behalf of Expert Village I'm going to be showing you how to use your jacket or your hooded sweat shirt in a defense situation. I'd like to talk to you a little bit about some of the... Read More »
On behalf of expertvillage.com, my name is Allison at Western Art Glass. We are talking about soldering sun catchers. We solder the front side and we want nice rounded solder beads. It looks good and it makes your sun catcher stronger. So we don't want... Read More »
Hi, I'm Carla, queen of Karaoke. I'm going to explain to you how to run a great Karaoke show. The first important tip we start with the sign up sheet, most people use a piece of paper. Piece of paper is much too rigid and hard to work with. It's much... Read More »
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 03:40 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-11-2008 12:47 AM
Flexible copper gas line wease Plumbing 6 04-09-2008 12:40 PM
Flexible copper in attic space Lmiller Plumbing 1 03-11-2008 10:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
