Flex To Solid Metal Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 08:49 AM   #1
Flex to solid metal ducting
Good monring.....I was thinking of changing my home air delivery flex tubing to solid piping and covering with insulation myself......
1) Can I downsize the pipes do to less restriction in the air flow?
2) I have talked to multiple HVAC techs and they all say the most bang for your buck is to swap out the ducting with a superior product....Any experienced thoughts on that ......each one I talked to was not interested in the job, so they werent trying to sell me on the idea. The one contractor who said to swap it was the contractor on the job for my specific home and he knows they used inferior cheap products on these track od homes.........ANY THOUGHTS??
nzvlnr is offline   Reply With Quote
Old 09-14-2011, 09:11 AM   #2
Start with checking the airflow coming out of the grilles(remove grilles first)is there good air movement?
the cheap flex duct are not sold in america.just a bunch of BS here.
the grilles are stamped steel(3/8" air gap)if you want better airflow go with an up grade and replace the grilles with the bigger openning between fins.
re-place the filter grille w/hinged filter grille.
Marbledust is offline   Reply With Quote
Old 09-14-2011, 04:23 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Yup, one size smaller but have your hvac tech make certain of the cfm.
Doc Holliday is offline   Reply With Quote
Standing seam metal in NJ pcampbell Roofing/Siding 1 05-12-2009 07:10 PM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 01:03 PM
Latex versus Oil On Bare Metal. Does Latex Cut It? TomBrooklyn Painting 3 01-21-2009 07:36 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 02:30 PM
