Flex Pipe Soaked? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 01:03 AM   #1
Rewards Points: 518
Flex pipe soaked?
We have two fresh air intakes into our furnace room. One runs to the return air ducting and the other to a combustion pot in the floor. They are both the same material seen in the picture below(yellow insulation inside, black plastic outside).
Yesterday we had a temperature change from -10C up to +4C over night. I noticed water leaking from the return air pipe. When I ripped a hole in the black plastic the insulation was soaked. This is definitely from the temperature change where the warm house air is meeting the outside air. My question is, is this normal with such a drastic temperature change? Is the insulation inside this pipe garbage now?
(leaky return air not shown, but exact same 6" pipe material)
n0c7 is offline   Reply With Quote
Old 02-17-2010, 03:33 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
I think it is a co-incidence. Probably you had snow sucked into the fresh air pipe (the other is a combustion air pipe) and it melted. Seen that happen with HRVs. You would need to replace it as it may get moldy. Make sure the intake has a screen and snow does not get piled up nearby/swirl and get sucked in. HDepot may sell it as I have bought it from them before.
Old 02-17-2010, 04:45 PM   #3
Rewards Points: 518
We had a sidewalk poured in that area in the fall and we kept the snow cleared all year long. Only chance snow got up in there is if it blew in.
Old 02-17-2010, 04:57 PM   #4
Hvac Pro
yuri's Avatar
It got in somehow. Or the exhaust from a clothes dryer or furnace is recirculating and getting sucked in and condensing. Does the vent face due North? I have a customer with a HRV which is getting snow in the intake when a strong North wind blows.
Old 02-19-2010, 11:24 AM   #5
Rewards Points: 518
There is a dryer vent a few feet away but an A/C unit separates them. It's a south facing wall tightly in between two houses. Could very well be snow, but you would think this would melt inside the pipe, not get the insulation in between the pipe and the plastic wet?????
Old 02-19-2010, 03:38 PM   #6
Hvac Pro
yuri's Avatar
The inner plastic liner is VERY thin and easy to perforate and may have a rip/hole in it from the installers.
Old 02-20-2010, 06:47 PM   #7
Ooops
okrite is offline   Reply With Quote
Old 02-20-2010, 06:51 PM   #8
cut it again
Hey Yuri,
Cut another piece off one end and put it on the other, least one end will be long enough.
Old 02-20-2010, 06:58 PM   #9
Hvac Pro
yuri's Avatar
Oy. Now you got me drink/thinkin and I don't want to have a thinkin problem. Wasn't there a county song about that?
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-20-2009 12:53 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Flex line from black pipe to appliance kennethjyoung Plumbing 9 02-24-2008 07:21 PM
