Old 02-13-2007, 05:56 PM   #1
Flex Gas Line
We are installing a furnance temporarily while we finsih our basment and then run infloor heating on the main floor. I was wondering if you could use a flex gas line to connect the furnace to the main line? We are running a propane furnance.
Babybird is offline   Reply With Quote
Old 02-14-2007, 07:32 AM   #2
RippySkippy's Avatar
Flex Gas Line
Don't know what the code specifics are, but I did just that. The BI looked at it and said it worked for temp needs. I used black pipe from the furnace gas valve out about 6" to a shut off and a 90 to support the necessary downward bend and out to the main. If the temp furnace is out in the open, you might want to fasten it to the floor.
Rip
RippySkippy is offline   Reply With Quote
3/4" gas line needs to be bigger raymond_anthony HVAC 11 10-28-2009 06:59 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 02:41 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
