Old 08-25-2010, 09:53 AM   #1
flex duct turns
Should I have solid 90"S and 45's at the bends in my flex duct off the distribution box, and in the ceiling registers?
sjthompson is offline   Reply With Quote
Old 08-27-2010, 08:22 PM   #2
flex duct turns
Although not absolutely necessary, I would recommend it. I have seen too many installations where the flex duct has nearly collapsed into itself on bends. A hard elbow is clearly better.
MI-Roger is offline   Reply With Quote
Old 08-27-2010, 09:40 PM   #3
An old Tradesmen
flex duct turns
Care must be taken not to kink the flex when making turns/bends.
If you really want to use hard pipe ells, nothing wrong with that.
Old 08-27-2010, 10:20 PM   #4
Wire Chewer
Red Squirrel's Avatar
flex duct turns
I would avoid flex where you can, in permanent setups. Think of how much more dust they will collect over time due to how they are made.
Old 08-28-2010, 06:58 AM   #5
flex duct turns
If you are making bends or connecting flex to register boots make sure you use a wide radius when making the turns and support them if needed.
No sharp bends.
COLDIRON is offline   Reply With Quote
Old 08-28-2010, 07:40 PM   #6
flex duct turns
so how much diffrence does it make how tight the turn is into the register box? All mine are laying on the insulation on the attic floor and the just 90 down into the register box.
Old 08-28-2010, 09:02 PM   #7
An old Tradesmen
flex duct turns
The tighter the 90, the more restricted the air flow is.
Hop in your car. Drive around the block. The first 2 turns, make them wide. Make the next 2 turns very tight. Feel the difference. It has the same effect on air. Throws more air to the one side, and slows it down.
Old 08-28-2010, 10:27 PM   #8
Moderator
flex duct turns
I would. You should be one size bigger on the straight runs: http://rockwallcontrols.com/Resident...ag=air-ducting
Pressure losses: http://www.mmmfg.com/pdfs/True_Cost_...x_10-27-06.pdf
http://www.thefreelibrary.com/Pressu.....-a0201591046
Gary
Clothes taking longer to dry?
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
flex duct termination issue LanterDan HVAC 2 02-12-2009 06:59 AM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 09:07 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
