Old 11-03-2007, 10:10 AM   #1
Flex Duct Reduction
I am installing AC in a home and need to use Flext Duct for some lines. What is the best method to go from one side to another. 10" main to 6" feeds and reducing from 10" to 8".
Do I just use normal Tees?
mwhiting0402 is offline   Reply With Quote
Old 11-03-2007, 11:45 AM   #2
ICF Construction
Flex Duct Reduction
Duct work requires math, arbitrarly just putting on pipe is not always a good idea. you need to find someone to size the ducts you need. Not doing this can cause undue stress on a system by either too much back pressure or not enough and the system runs too long. There is a science to this. Consult a local HVAC designer for more assistance.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-03-2007, 12:24 PM   #3
Flex Duct Reduction
Actually I have the sizes determined for both the supply and the return.
What I am looking for is how to run lines off one size flex duct (10") to another.
It seems odd to put sheet metal tees in each joint.
What is the best method to branch off or change size in a run?
Old 11-03-2007, 02:30 PM   #4
ICF Construction
Flex Duct Reduction
Okay if you had it designed then you should be good to go, I hate to say it use a sheet metal Y to create your branches, it seems to be what everyone is doing.
Chris
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 03:30 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 02:12 PM
