Flex Duct Connector - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 05:30 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Flex duct connector
My furnace has a slight vibration when the inducer motor kicks on that radiates into the framing of the house. It's not bad, but I would prefer it not be there. Could I use one of these in the return plenum near the furnace?
MikeKy55 is offline   Reply With Quote
Old 01-26-2011, 05:42 PM   #2
Rewards Points: 1,216
Yes, most well installed HVAC systems will have one on the supply duct and the return duct.
COLDIRON is offline   Reply With Quote
Old 01-26-2011, 06:33 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
I don't know about well installed! Those things leak and look horrible! A good installation wouldn't need that and instead be transitioned in the field with sheet metal. The inducer should not be vibrating, especially the whole furnace, to the point you hear it through the house.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-27-2011, 06:59 AM   #4
hvactech126 You are totally wrong in your answer.
They are designed to stop vibration not look pretty.
Old 01-27-2011, 05:26 PM   #5
AKA HVACTECHFW
a correctly installed and maintained furnace wont vibrate
IT IS WHAT IT IS
Old 01-27-2011, 05:35 PM   #6
MikeKy55's Avatar
Rewards Points: 254
Hummm.... now it may make better sense to find out why the vibration is there. Probably no more costly and most likely less work. Thanks for the wake up.
Old 01-27-2011, 05:39 PM   #7
Question, Why did they invent canvas connectors??
Answer, to stop unnecessary Harmonic distortion from ductwork to the entire house.
FYI: Vibration eliminators on all large/small piping systems, ductwork, bridges, buildings.
Signed 40 Year HVAC Mechanic
PS: By the way canvas connectors are the proper term of what was shown in the picture if you didn't KNOW.
Old 01-27-2011, 10:29 PM   #8
MikeKy55's Avatar
Rewards Points: 254
Thanks COLDIRON. I didn't know the correct term.
Old 01-28-2011, 05:27 AM   #9
An old Tradesmen
Rewards Points: 6,468
A flex/anti vibration connecter is actually required by code on sheet metal duct systems.
Old 01-28-2011, 06:49 AM   #10
"Thank You very much beenthere"
Old 01-28-2011, 07:19 AM   #11
AKA HVACTECHFW
In your area, not here
IT IS WHAT IT IS
Old 01-29-2011, 07:24 AM   #12
An old Tradesmen
Then your area isn't following/enforcing them IMC. International Mechanical Code.
Old 01-29-2011, 10:07 AM   #13
AKA HVACTECHFW
I'm assuming you are talking about section 603.6 NO where in this section discussing Flexible air ducts and flexible air connectors does it say they HAVE to be used.
otherwise section 301.10 Vibration isolation
Where vibration isolation of equipment and appliances is employed, an approved means of supplemental restraint shall be used to accomplish the support and restraint.
again nothing stating you HAVE to use a flex air connector
please if you have the specific section that says what you are referring to, then let me know!
IT IS WHAT IT IS
Old 01-29-2011, 10:21 AM   #14
An old Tradesmen
From 2006
I.M.C. - Section 603.1.1, Vibration isolators.
Section 603.1.1, Vibration isolators, is hereby added to read as follows:
"603.1.1, Vibration Isolators. When equipment is supported by a concrete floor slab, vibration isolators shall be installed between mechanical equipment and metal ducts and shall be of an approved material not less than three inches (75 mm) nor more than ten inches (254 mm) in length."
Old 01-29-2011, 10:29 AM   #15
AKA HVACTECHFW
i have the 2006 book in front of me and there is no 603.1.1 only a 603.1 and does not have the section listed Vibration isolators
this code you listed states "When equipment is supported by a concrete floor slab" So not all furnaces are required to utilize flex air connectors.
IT IS WHAT IT IS
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 05:35 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
