Old 07-23-2008, 02:06 PM   #1
Send a message via AIM to ssporty21228 Send a message via Yahoo to ssporty21228
Flex Duct Advice
I want to replace flex duct in my attic that's old and deteriorating. I have 1600 sq ft. 3 bedroom 2 1/2 bath home with a pyramid style roof and the coil about centrally located in my attic. My question is this... what size diameter flex duct do I use to get the best deliver of cold air to the different rooms of the house....?
Currently in my living room there's 8" diameter duct going to 2 registers one is approx. 15 ft. long and the other about 4 ft long, the room is 336 sq ft. with a 9 ft. ceiling.
The duct going to my kitchen is 8" in diameter and approx. 17 ft. long, the room is 130 sq ft. with a 8 ft. ceiling.
The duct going to my master bedroom 9" in diameter and approx. 14 ft. long, the room is 182 sq ft. with a 9 ft ceiling.
The duct going to my secondary bedroom is 6" in diameter and approx. 19 ft. long, the room is 130 sq ft. with a 8 ft. ceiling.
The third bedroom has a 6" diameter duct and is approx. 15 ft. long, the room being the same dimensions as the secondary bedroom.
I'm a newbie so any help or insight will be greatly appreciated!
ssporty21228 is offline   Reply With Quote
Old 07-23-2008, 06:46 PM   #2
Flex Duct Advice
unless there is a problem with airflow in one of the rooms use the same size. R-8
and for runs over 15 feet use hard pipe wraped with 3 inch insulation
geo fan is offline   Reply With Quote
Old 07-23-2008, 08:15 PM   #3
Flex Duct Advice
So, you say replace flex duct with hard pipe for runs over 15 ft...is this because of less resistance?
And what diameter of hard pipe should I use?
And the runs that are currently installed that are 6" in diameter, should I up those to 8" also?
Also, these 6" diameter runs branch off of the 8" runs...should I continue these branches or cut new holes in my plenum to run them from?
And...the register closest to the coil is 9 degrees colder than the other registers in my house...is this normal and what if any temp difference should there be?
Old 07-23-2008, 08:45 PM   #4
Flex Duct Advice
r8 is the flex insulation rating not the size , yes less resistance it's code here
the temp difference between registers is a product of inadequate insulation or leaky ducts ,pipe size only effects volume of air not temp. So to start from the beginning replace everything with the same size , excessively long runs should be done mostly with hard pipe of the same size with 3 inch insulation. If there is no problem with rooms being different temps don't bother redesigning the duct's just direct replacement with improved insulation rating
Old 07-23-2008, 09:28 PM   #5
Flex Duct Advice
For the info Geo...I'll definitely take your advice!
To Insulate or Not (Flex Duct) BasementDweller HVAC 1 07-21-2008 10:03 PM
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 07:07 AM
Need advice on how to screw thru a duct? Chip718 General Discussion 3 04-08-2007 03:28 PM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 03:30 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 02:12 PM
