Flex Duct - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 02:25 AM   #46
Rewards Points: 150
Well I'm stapling it to the bottoms of the ceiling joists so use mastic where the board meets the wood and the seams?
Mijotter is offline   Reply With Quote
Old 01-15-2013, 05:15 AM   #47
An old Tradesmen
Rewards Points: 6,142
Yes..
Old 01-15-2013, 05:27 PM   #48
Rewards Points: 150
Exclamation
So I got some Knauf Duct Board at a very good price. However, once I got it home it seems very...fibrous. I run my hand calmly over the fiberglass portion and it feels like i'm scraping off very small particles. Is this normal?
It has the intent of being used as a return plenum so air flow shouldn't be TOO aggressive right?
Is there some kind of guard that I could place over it to prevent that from entering the rest of the house if it is indeed a problem or perhaps a special air filter?
In the picture does this mean that the board was made November 16th 2000?
Does the duct board look in good condition from the pics?
Old 01-16-2013, 06:19 AM   #49
An old Tradesmen
Return air flow velocity is suppose to be low, so it shouldn't pick up any fibers.
Nothing you can really put on. they make duct board with a coating already on it, but no coating to put on after the fact.
Yep, its old.
Old 01-19-2013, 06:25 PM   #50
Rewards Points: 150
Exclamation
Will Titebond Acoustical Sealant work with sealing the duct board?
http://www.titebond.com/product.aspx...c-bcb5e1c603b5
Old 01-19-2013, 06:45 PM   #51
Rewards Points: 150
I'll be using it on the outside of the duct work to seal to the ceiling joist.
Old 01-20-2013, 06:09 AM   #52
Rewards Points: 150
Exclamation
Ok got the first return duct board all up and it went surprisingly well for my first time. Really killed the sound and resonance too Now I just have to seal it properly to each other and the wood joists so a couple question so I do it correctly;
1. Should I run a bead of duct sealant caulk the whole length where the yellow fiberglass meets the joist. (It's pretty tight, did a light test and it passed)
2. Should caulk AND tape all the seams or just taping will be fine?
3. My joists aren't perfect and there are 2 gaps where the joist was chiseled and there's about a 1/4" small gap. Just fill with caulk?
4. How would I go about sealing the duct board to the concrete wall and the wood frame on either end of the run?
Thanks to everyone for their help in this.
Flex Duct-100_3442.jpg   Flex Duct-100_3445.jpg   Flex Duct-100_3444.jpg   Flex Duct-100_3441.jpg
Old 01-20-2013, 06:19 AM   #53
An old Tradesmen
Run a bead of caulk on all seams. Then run a strip of foil tape over top of that and staple the tape to the duct board and wood.
At the concrete end. just caulk.
Old 01-21-2013, 06:50 PM   #54
Rewards Points: 150
Is this tape good to use?
Old 01-21-2013, 06:55 PM   #55
An old Tradesmen
Should work fine.
Tags
air , flexduct , furnace , plenum , return
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 05:35 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
