Flex Duct - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 10:16 PM   #16
Rewards Points: 150
Well There is another return plenum the same size coming from the dining room(the other end of the house.) Will that help? And every room has a small return in it as well.
Mijotter is offline   Reply With Quote
Old 01-11-2013, 10:19 PM   #17
An old Tradesmen
Rewards Points: 6,140
You may or may not have enough return already. Does your air filter bow in.
Old 01-11-2013, 10:26 PM   #18
Rewards Points: 150
How would I check that? Sorry bit of a noob here and thank you in advance.
Old 01-11-2013, 10:32 PM   #19
An old Tradesmen
Look at the filter and see if its bowed in toward the blower. Its probably in the furnace near the blower.
Old 01-11-2013, 10:37 PM   #20
Rewards Points: 150
ok give me a minute.
Old 01-11-2013, 10:47 PM   #21
Rewards Points: 150
yes it was bowed.
Old 01-12-2013, 01:38 PM   #22
Rewards Points: 150
The fabric in the middle was definately bowed and the outlining of the filter was slightly.
Old 01-12-2013, 03:42 PM   #23
An old Tradesmen
Now you just need to determine if its because of low air flow or not changing it often enough.
Old 01-12-2013, 03:52 PM   #24
An old Tradesmen
No need to line duct board as the fiberglass helps to absorb sound.
Old 01-12-2013, 03:54 PM   #25
Rewards Points: 150
well it's VERY thin Thermopan:
http://www.thermopan.com/thermopan.htm
Would that call a duct liner?
Old 01-12-2013, 04:05 PM   #26
An old Tradesmen
Thats not duct board. Basically its not line-able. No ability to pin the liner. 3M spray glue may work.
Old 01-12-2013, 04:10 PM   #27
Rewards Points: 150
ugh oh man. So i'm looking for something like this?:
http://www.specjm.com/products/ductb...icroairelp.asp
Old 01-12-2013, 04:18 PM   #28
An old Tradesmen
can use their regular duct board.
http://www.specjm.com/residential/ai.../ductboard.asp
All duct board has sound attenuating properties.
How bad was the sound transfer through those returns.
Old 01-12-2013, 04:23 PM   #29
Rewards Points: 150
It was pretty bad with the old sheet metal. Resonance was high and would travel up through the vent in the floor above with ease. Could the JM duct board be installed in between the ceiling joists or should it be stapled to the bottoms of them?
Are you referring to just the flat pieces and not the box shaped ones?
Old 01-12-2013, 04:29 PM   #30
An old Tradesmen
Flat stock.
Yes, it can be installed so that it is flush with the bottom of the joist.
Tags
air , flexduct , furnace , plenum , return
Using flex duct for return. lakeresident HVAC 3 11-14-2011 10:56 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 05:35 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
