Flex Connector - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 07:12 PM   #1
flex connector
is a flex connector between the plunmum and main trunk line necessary?
buck545 is offline   Reply With Quote
Old 05-01-2013, 07:26 PM   #2
Rewards Points: 582
removed comment
Old 05-01-2013, 08:55 PM   #3
An old Tradesmen
Rewards Points: 7,372
It is a code requirement. However, your area may not enforce that code.
Old 05-02-2013, 05:53 AM   #4
Rewards Points: 1,216
Originally Posted by ben's plumbing View Post
removed comment
Like the reason for edit.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
ben's plumbing (05-02-2013)
What's the name of this connector? dasgata Carpentry 7 11-03-2011 09:13 PM
OK To Bend A StrongTie Sheet Metal Hanger Connector? Gordo Burgess Building & Construction 5 10-12-2011 07:55 PM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
Flex duct connector MikeKy55 HVAC 17 01-29-2011 09:38 AM
SS flexible connector with nut? oldnightnurse Plumbing 38 05-21-2008 06:40 PM
