Flatter Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 08:47 AM   #1
Flatter duct work
There is a branch (7" x 11'") off the main supply that is surface mounted to my joists.
Since I am trying to gain some extra head clearance, I am wondering if I can replace the existing duct with a flatter profile duct (say 4" x 20")?
Theoretically I would be moving about the same volume of air?
What do you think?
allthumbsdiy is offline   Reply With Quote
Old 09-09-2012, 09:00 AM   #2
HOTDAWG
Yes you can, if you go shorter you just need to make up the volume by widening the duct work.... gets a little more expensive, but will give you the head room.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
allthumbsdiy (09-09-2012)
Old 09-09-2012, 10:19 AM   #3
awesome. thank you
Old 09-09-2012, 12:01 PM   #4
Air starts acting goofy when you get out past a 3/1 aspect ratio. It tumbles in a more circular motion not using the corners of your 7x11. Dropping down to a 4x20 will have 2 columns of air with neither using corners. So even though the area is the same it will not have the same air flow. Still could be good enough if the room really didn't need that much to begin with.
The Following User Says Thank You to Marty S. For This Useful Post:
Old 09-09-2012, 12:33 PM   #5
An old Tradesmen
Rewards Points: 8,154
Its not just the open area of the duct that counts. Its the amount of surface area also. A 7X11 duct has a 3 sq ft of surface area for every 1 foot of linear length, and a 4X20 has 4 sq ft of surface area for every 1 foot of linear length. So 4X20 won't flow as much air as a 7X11 at the same static pressure. You would need to be about a 4X24, and the take offs would have to be set back almost 6" from the face of the duct, to get the same amount of air to go into the take off.
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-09-2012, 03:37 PM   #6
thanks for the lesson in air flow!
i decided to keep it as is, but extend it towards a wall.
Old 09-09-2012, 04:40 PM   #7
An old Tradesmen
Your welcome. keep us updated.
Advice for installing duct work for finishing basement captainj98 HVAC 1 05-11-2011 07:01 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
fans and duct work kjacobs4242 HVAC 2 09-26-2010 04:15 PM
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 07:29 PM
Toughest duct work I can get? napper HVAC 7 07-30-2008 10:52 AM
