Flare Nut Types - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 11:08 AM   #1
Flare Nut types
Is there a difference between a HVAC flare nut for R410A and a flare nut one would find at Lowes/Home Depot?
I need to get from a 3/8" to a 1/2" connection for my mini split but the adapter seems to be leaking. I was wondering if there is angle difference with flare nuts????
Joe Banks is offline   Reply With Quote
Old 03-02-2011, 03:19 PM   #2
Usually a flare nut is a flare nut. Most times you have a leak because of the flare.
Hubcap626 is offline   Reply With Quote
Old 03-02-2011, 04:43 PM   #3
newtech's Avatar
Rewards Points: 164
[quote=Joe Banks;601037]Is there a difference between a HVAC flare nut for R410A and a flare nut one would find at Lowes/Home Depot?quote]
Yes there could be a difference. Most 410a flare nuts are thicker than the standard flare nut that you can buy at the box stores.
If you are matching it with a mini split the angle might be slightly different also. Might need a 410a flare tool as well.
newtech is offline   Reply With Quote
Flare nut for gas connection- question daveaust Plumbing 3 01-09-2011 08:48 PM
Flare unions and pipe dope when installing gas stove line BrainDoc Plumbing 1 09-11-2010 10:42 AM
Gas valve flare end conncetion? diggerdave Plumbing 1 02-09-2009 10:06 PM
Propane lines in an RV...Flare Fittings K-mann Plumbing 3 09-18-2008 09:06 AM
Types of Earwigs and features of Earwigs Pholma Pris Pest Control 4 11-20-2007 05:19 PM
