Flammable Foil Tapes - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 12:31 PM   #1
rkj
Rewards Points: 79
I thought all foil tapes were non-flammable, but I guess I was wrong:
So, do they make foil tapes thare are not flammable or spread fire? The person in the video mentions a tape called "citi" but I can't hear it correctly. If you know of any foil tapes that don't spread fire, let me know. Doesn't look like "UL" listed matters in this case.
rkj is offline   Reply With Quote
Old 11-06-2013, 10:14 PM   #2
Rewards Points: 242
it looks like the only thing that was burning was the glue on the back.
when applied on the ductwork, the glue would not be showing so would take awhile to burn.
hvac instructor is offline   Reply With Quote
Old 11-06-2013, 10:56 PM   #3
rkj
Rewards Points: 79
True, but it still looks pretty bad. Do they make any foil tapes that don't burn like that? Anyone every try putting this type of tape on a flame?
Old 11-06-2013, 11:34 PM   #4
Rewards Points: 13,300
Why would we.
If your duct work is getting so hot the tape is catching on fire your in deep dodo and no non flammable tape is going to help.
yuri (11-07-2013)
Old 11-07-2013, 12:17 AM   #5
Rewards Points: 6,652
The one on the right does not have the paper on the back, the one on the left does. Also the glue used can be flammable, but the packaging would state that info.
Old 11-08-2013, 01:31 PM   #6
rkj
Rewards Points: 79
Originally Posted by joecaption View Post
Why would we.
I think if a "non flammable" tape was available, then it wouldn't spread the fire once it had started.
He says in the 24 to 27 mark of the video that the protective paper was removed.
You're right, it is the glue from the looks of it. I wonder if it was rubber glue, acrylic or something else.
Old 11-08-2013, 01:56 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
everyone is trying to differentiate their product/ run down the others to try get sales. much a do about nothing IMO.
most people die in house fires in less than 5 mins because furniture and carpet and drapes etc gives off TREMENDOUS amounts of toxic smoke and the flash point/ flash over happens quickly. ever watch those shows where they torch a room and show you how smoke rises and everything flashes into a fireball in less than 5 mins. the foil tape has nothing to do with a real fire.
Old 11-08-2013, 03:00 PM   #8
First clue is that this is a Youtube video. Second clue is that this is a Youtube Video. As a magician states, they never reveal their secretes.
As for the tape, yes there are versions out there that have a glue backing or are foil/mylar over paper, but the mass majority you find in the hvac aisle at Lowe's, Menards, Home Depot, will be true foil tape.
Get it at Wally World, you never know what you are getting.
Old 11-08-2013, 03:16 PM   #9
Hvac Pro
yuri's Avatar
could have sprayed WD40 on it and voila. flambé.
The Following User Says Thank You to yuri For This Useful Post:
gregzoll (11-08-2013)
Old 11-08-2013, 03:48 PM   #10
Anything to amaze the audience and spread FUD through the Youtube video world. Worse thing that ever happened to society was giving the mass majority Youtube.
Do not get me wrong on Youtube. There are some good ones on there, and then there is a lot, and I do mean a lot of really bad ones that make you cringe, when you see them.
I really hate the ones, that the person spends five to ten minutes, moving the camera between some papers and some tools, and 30 seconds of actually showing you what the video is about.
Anymore Youtube is nothing more than a soapbox for those who think that they have a audience.
Old 11-08-2013, 04:36 PM   #11
Hvac Pro
yuri's Avatar
some are really good as I found a good one about parging my foundation walls (touching up the cosmetic stuff) but you have to sift thru a lot of crap to get there. Worst part of my biz and on some forums is these wannabee techs spewing dangerous and misleading BS and having Joe homeowner try them. now that is dangerous.
Fiberglass insulation with foil backed foam sheathing thedudeabides! Insulation 2 02-01-2012 11:48 PM
Cold Air Return Ducts & Aluminum Foil kim23 HVAC 10 09-23-2011 02:00 PM
ao smith flammable vapor detector aosmithsicks Plumbing 2 06-10-2011 07:59 AM
Can foil faced foamboard insulation be layered? Spud Building & Construction 10 09-30-2010 07:41 PM
19" spaced joists - foil faced insulation? CWorth Remodeling 3 03-21-2009 01:26 PM
