Flame Sensor Location - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 12:13 PM   #1
flame sensor location
I have a lennox g 26. the instructions i received from this site (and thank you) were that the flame sensor would be located "If you look underneath the burners, you'll see 2 screws attaching the burners to angles on the box wall. Remove those 2 screws, then carefully slide out burner assembly. The flame sensor is on the top left." I took mine apart and there is nothing on that left side under the burner. I have a yellow wire running from the control to a what i beleive is the flame sensor right beside the intermittent pilot, That make sense to anyone??
trump is offline   Reply With Quote
Old 12-20-2009, 12:22 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,268
what is the complete model # of that unit. There are several variations of it. Post some pics of the burner box area and the the unit with both doors off.
Old 12-20-2009, 12:24 PM   #3
Should be 2 wires on the intermittent pilot model. One yellow or orange goes to the ignitor on the pilot hood and the other is a white cloth covered wire that goes to the flame sensor.
Old 12-20-2009, 12:25 PM   #4
it is a lennox g26 Q 3/4- 125-1 will post pics in a bit when i figure out how thanks
Old 12-20-2009, 12:29 PM   #5
Hvac Pro
yuri's Avatar
That unit has the flame sensor built into a pilot burner. It is VERY fragile, porcelain deteriorates and I always replace the complete pilot burner and flame sensor as one unit. 99% of the time the porcelain crumbles and I am a Pro so you are warned. The later G26's have a regular flame sensor which can be cleaned. Best to get a Lennox tech to replace it or leave it ALONE until it and the board malfunction. 50% of the equation is the pilot burner gets corroded/warped and not cleanable so cleaning the sensor only does half the job.
Old 12-20-2009, 12:33 PM   #6
thanks i already took it apart and cleaned it was able to get it back together no prob so far. i was just confused about the location of the flame sensor thanks again
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 12:36 PM
York Diamond 80 Intermitten Flame Setdyi HVAC 38 02-08-2014 12:20 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 08:19 AM
Gas Fireplace Pilot Flame MicRos HVAC 2 11-01-2009 06:15 AM
Flame blowin' in the wind... testeng HVAC 4 10-28-2007 03:11 PM
