Flame Sensor Ducane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 09:12 AM   #1
flame sensor ducane furnace
where is located flame sensor in ducane furnaces,i take the cover pannel off but i dont see metal rod sensor?
real madrid is offline   Reply With Quote
Old 02-16-2012, 12:02 PM   #2
how
Rewards Points: 1,070
USUALLY
If the furnace has a pilot, then it would be situated in the pilot flame. If you have a hot surface igniter then it would be in the burner flame path that is furthest from the igniter.
age & model of the Ducane would help.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
dosy777 (02-16-2012), plummen (02-16-2012)
Old 02-16-2012, 12:51 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
post some pics of it with the cover off. Ducanes can be a HUGE pain in the butt to get at the sensors. Some of them have Smartvalves too and you don't really ever want to try clean that sensor as it is built into the pilot burner which breaks the HSI easily. I have not had a lot of issues with the sensor getting dirty on smartvales, more the valve itself. If the gas valve has a number like SV9500xxx then it is a smartvalve.
Old 02-17-2012, 08:08 AM   #4
HVAC Tech/ Browns Fan
You need replace the whole then. Its called sensor/ ignitor you are better off replace whole then. Must the time if you try to clean that small flame sensor you will end up breaking the rod. The cost can be under 140.00 online price. You have a smart valve gas valve that is a very important part need updated. P.s be really careful replacing it.
Tator1076 is offline   Reply With Quote
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 09:13 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Trane Gas Furnace - blower on but no flame at burners herbert8101 HVAC 2 09-24-2011 09:23 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
