Flame Sensor - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2005, 01:38 PM   #1
flame sensor
where is the flame sensor located on the furnace?
tbristolb is offline   Reply With Quote
Old 03-30-2005, 01:48 PM   #2
jproffer's Avatar
Rewards Points: 706
You mean the thermocouple i assume...find the gas line coming in...this should come into the gas valve...then on the bottom will be a small metal tube...that goes into the burner chamber..follow it.
If it needs to be replaced, just pop out the old, go to (***your favorite***) Hardware and get a replacement, and pop in the new. Some just "pop" in and out like that...some you will need a wrench for. The end on the gas valve almost always takes a wrench to remove. In fact, I hate to say always, but I can't think of ever seeing one that just came out freely on that end.
jproffer is online now   Reply With Quote
Old 04-04-2005, 04:25 PM   #3
It depends on the brand and type of ingition. Call the factory and get a pictured parts info mailed to you.
rabadger is offline   Reply With Quote
Old 04-10-2005, 10:06 PM   #4
Smile
flame sensor location
:p
Depending on the make of furnace , it'll be a thin steel rod somewhere in the outlet of one of the burners . Directly in the path of the flame for instant contact. LOL Jack
jack hoseman is offline   Reply With Quote
Who makes the best stud sensor? kcrossley2 Building & Construction 6 03-19-2007 12:31 PM
Comfortmaker Furnace GUH Series Issue Ghengis Jon HVAC 8 03-01-2007 03:02 PM
weatherking furnace blower runs continuously rayborj HVAC 4 12-08-2006 03:23 PM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 10:18 PM
