Old 01-20-2010, 07:04 PM   #1
Flame rollout switch
on my bryant furnace, My filter was very dirty and I got a message 33/13. I replaced the filter and now need to reset the flame rollout switch. I found the switch, but it wont click to reset. any advice?
rmason is offline   Reply With Quote
Old 01-20-2010, 07:25 PM   #2
Shouldn't get flame roll out from a dirty filter but you will trip the limit. Turn the power off and then back on to reset the control board. Sometimes those limits trip one too many times and will not close again.
Old 01-20-2010, 07:28 PM   #3
I've turned the power off and turned it back on. The limit switch doesn't want to reset and I keep getting a 13/33 everytime I turn it on. Could it be a bad switch?
Old 01-20-2010, 07:41 PM   #4
Probably. Need to check it with a meter to be sure. Here's something to try for temp heat. Turn the power off, remove the limit and tap it with your finger then reinstall. Sometimes that will get them to close but it will still need to be replaced.
Old 01-20-2010, 07:43 PM   #5
Thanks, I'll go give it a try.
Old 01-21-2010, 08:36 AM   #6
HVAC Tech/ Browns Fan
If you know the roll out switch is trip. That is a big promblem like crack heat exchanger, dirty burners or plug up heat exchanger. When you fire it up watch for roll outs that is flame rolling out to you.
Tator1076 is offline   Reply With Quote
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Goodman Rollout switch problem? Thermographer HVAC 3 01-15-2009 04:22 PM
Small flame behind light switch when off duffeymt Electrical 9 09-06-2008 12:05 AM
Carrier Weathermaster 9200 flame roll-out switch problem jamesbond HVAC 4 12-05-2007 07:55 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
