Fixed Pilot Light, Now Furnace Or AC Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 11:24 PM   #1
Fixed pilot light, now furnace or AC won't turn on
A bit of history,
This is a 20-something year old York central air system and gas furnace. Central air worked all summer.
The pilot light on the furnace went out some time in the last few months (last time I saw it on was July).
The pilot light wouldn't re-light, so I replaced the thermocouple. Now the pilot light stays lit.
However, now the furnace will not turn on. I set the thermostat to "heat", hear the thermsotat click on, but nothing happens on the furnace unit itself. What is also interesting is if I set the thermostat to "cool" and turn it down below room temp, the AC will not kick on (outdoor unit AND blower).
The furnace has what appears to be a test button, seen at the far bottom of my attached picture. When I press that while the thermostat is set to "heat", the burner lights up. As soon as I let go, the gas shuts off. When the thermostat is set to "cool" and I press that button, the blower motor turns on (outdoor unit does not).
I think I'm missing something simple here. When I changed the pilot light TC, the only things I touched were the thermocouple wire, the pilot light gas tube, and shut off the electricity to the furnace via the switch on the far right of the attached picture.
Any thoughts as to where to start troubleshooting? Thanks in advance!
mjcfromct is offline   Reply With Quote
Old 10-17-2011, 11:30 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
there is a blower door switch.... the blower door must be on........ depending on your thermostat when you remove power and then return power to the stat it has a 5 min delay before turning on the outdoor unit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-17-2011, 11:46 PM   #3
hvactech126,
You confirmed something for me - I was missing something simple!
What I incorrectly called a "test button" in my original post was the door switch. I had the blower door off the whole time!
Thanks for pointing out the obvious. Sometimes folks need that.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 07:41 AM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 12:47 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
