Old 02-16-2013, 11:38 AM   #1
Fixed heater?
American Standard Freedom 80
Woke up and house was cold. Thermostat could activate circulation fan. Furnace exhaust fan was running non stop.
Went through reset process (lower therm, shut off power to furn, furn gas valve off, wait 5 min. etc) When I brought it back up, exhaust fan would kick in for about 15 sec. and then stop. Would recycle repeatedly every 45 sec +/- same result.
On a whim I disconnected and reconnected all wire harnesses and connectors. Now furnace is working. Am I good to go, or is there something else I should do to make sure it keeps working?
edenprairie is offline   Reply With Quote
Old 02-16-2013, 01:39 PM   #2
Professional
Fixed heater?
If it happens again, check the flash codes to find out what error you are getting.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-16-2013, 01:45 PM   #3
Fixed heater?
How do I check those? Like older cars where you jumper wire diagnostic terminals and count service engine light flashes?
Old 02-16-2013, 01:47 PM   #4
Professional
Fixed heater?
Count the flashes. there should be a view port in the blower door so you can see the led on the control board flash.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (02-16-2013)
Old 02-17-2013, 11:06 AM   #5
Fixed heater?
sounds like the induced draft fan...air proving/differential air switch was not closing so, remove the hose and clean out the orifices at each end then place hose back on switch....suck and blow on and you should hear the switch click..you may have to use a paper clip or similar object to clean out the orifices...easy first step at no cost..IMO, worth doing.
techpappy is offline   Reply With Quote
Old 02-17-2013, 11:30 AM   #6
Fixed heater?
i had the SAME EXACT problem, on the same part. and i have seen it on a lot of electronics. they make the electrical connections so that they corrode over time. the corrosion is unseen. simply unplugging and replugging many times cleans the connection. get some electrical contact cleaner conditioner and use it.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 03:54 PM
Space Heater in Hot Water Heater Closet? MsMojoRisin Plumbing 0 02-09-2011 01:50 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
REZNOR gas shop heater WHOOMP ! on ignition Wildcat355 HVAC 14 01-29-2010 06:57 PM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
