-   -   Fixed heater? (http://www.diychatroom.com/f17/fixed-heater-172085/)
edenprairie 02-16-2013 10:38 AM
Furnace Fixed?
American Standard Freedom 80
Woke up and house was cold. Thermostat could activate circulation fan. Furnace exhaust fan was running non stop.
Went through reset process (lower therm, shut off power to furn, furn gas valve off, wait 5 min. etc) When I brought it back up, exhaust fan would kick in for about 15 sec. and then stop. Would recycle repeatedly every 45 sec +/- same result.
On a whim I disconnected and reconnected all wire harnesses and connectors. Now furnace is working. Am I good to go, or is there something else I should do to make sure it keeps working?
hvactech126 02-16-2013 12:39 PM
If it happens again, check the flash codes to find out what error you are getting.
edenprairie 02-16-2013 12:45 PM
Flash codes?
How do I check those? Like older cars where you jumper wire diagnostic terminals and count service engine light flashes?
hvactech126 02-16-2013 12:47 PM
Count the flashes. there should be a view port in the blower door so you can see the led on the control board flash.
techpappy 02-17-2013 10:06 AM
sounds like the induced draft fan...air proving/differential air switch was not closing so, remove the hose and clean out the orifices at each end then place hose back on switch....suck and blow on and you should hear the switch click..you may have to use a paper clip or similar object to clean out the orifices...easy first step at no cost..IMO, worth doing.
Fix'n it 02-17-2013 10:30 AM
i had the SAME EXACT problem, on the same part. and i have seen it on a lot of electronics. they make the electrical connections so that they corrode over time. the corrosion is unseen. simply unplugging and replugging many times cleans the connection. get some electrical contact cleaner conditioner and use it.
