Fix Leak Or Replace Coil--which? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 11:10 PM   #1
Rewards Points: 14
Fix Leak or Replace Coil--which?
I know my home A/C leaks. It had to be rechared a couple times last year. The technician said the coil needs to be replaced. But wouldn't just fixing the leak be cheaper? My house is ten years old. Should I replace the coil or try to find someone to fix the leak?
kkruecke is offline   Reply With Quote
Old 04-01-2010, 04:46 AM   #2
An old Tradesmen
Rewards Points: 7,372
Sometimes. You have to do more damage to the coil removing fins to fix the leak, that it doesn't cool as well.
Sometimes. After a leak is fixed in a coil. Another one shows up a week later, and then you end up paying for another repair, or replacing the coil anyway.
Replace is the better solution.
Old 04-01-2010, 08:51 AM   #3
Rewards Points: 14
ok, that makes sense. Thanks for the reply.
Old 04-02-2010, 10:22 PM   #4
I would think about upgrading to a 410A system. Your unit probably has R-22 in it. R-22 around here is getting very expensive.
richiemoe is offline   Reply With Quote
2003 Goodman coil leak singlemom5500 HVAC 2 08-17-2009 01:24 PM
Leak from air conditioning coil sjthomas2 HVAC 6 07-26-2009 10:20 PM
Small heating coil hydr0lic Electrical 7 07-22-2009 04:31 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
