Fitting For Static Pressure Test? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 12:19 PM   #1
raylo32's Avatar
Rewards Points: 1,252
fitting for static pressure test?
Crappy snowy day so I thought I'd try to get some static pressure measurements for my new furnace. I could probably improvise some way to connect up my manometer (1/4" tubing) to the supply plenum but I was wondering what you guys would recommend. Nothing promising at the local Home Depot... all the threaded fittings that had tubing barbs were at least 1/4" on the threaded end. I'd prefer something smaller... like maybe a drilled out automotive grease fitting. What do you guys use?
raylo32 is offline   Reply With Quote
Old 10-29-2011, 12:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
I use Pitot tubes
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2011, 12:29 PM   #3
biggles's Avatar
just for general readings starting right above the A coil at the air handler..just a drilled hole so the tube just bearly slips in static is the duct pressure like in a ballon tranverse it ever 5 '..might want to do a negative check from the filter rack up to the return...any leaking on the supply or return seal it with some brush on sealer...HD/LOWES max's out the system efficiantcy toward your benny.commercially they use a brass tube to sense static when controlling large rooftops and built up air handlers but you can do that tube only for your testing
Old 10-29-2011, 01:20 PM   #4
raylo32's Avatar
Thanks guys, I'll give it a try.
Old 10-29-2011, 03:08 PM   #5
An old Tradesmen
Rewards Points: 6,836
If you hv a furnace with A/C, the static for the supply is taken between the A/C coil and the furnace. And then between the air filter and the furnace/at the blower.
Old 10-29-2011, 03:55 PM   #6
raylo32's Avatar
Thanks for the tip. I was wondering whether to take it in the plenum or before the coil since the coil will add some backpressure. That'll be easy to test there since I have a 7" spacer between the furnace and N-coil.
Old 10-29-2011, 03:58 PM   #7
An old Tradesmen
The coil is external to the furnace, so the pressure must be taken before the coil.
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 01:37 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Pressure test water rough-in BillyD Plumbing 2 06-24-2008 02:12 PM
