First Time Using Programmable Themostat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 07:44 AM   #1
Rewards Points: 129
First time using programmable Themostat
My new home has a Venstar programmable thermostat as seen at the link below. I've never used a programmable thermostat, so I don't know what I really need to do to get the most out of it (for energy eff).
Obviously, I know that setting it to adjust temps for different times of the day can make it mor energy eff. But what else can I do with this thermostat to get the most out of it?
http://www.venstar.com/Thermostats/SlimlinePlatinumR/
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 01-13-2009, 11:40 AM   #2
What does it control: heat pump, furnace, humidifier, combination, etc? Temp setback is the main way you save on heating, but how far depends on what you're controlling.
dac122 is offline   Reply With Quote
Old 01-13-2009, 11:57 AM   #3
What model do you have? There's a lot of them there.
hvaclover is offline   Reply With Quote
Old 01-13-2009, 01:14 PM   #4
Rewards Points: 129
Sorry, the model is the T1900 and its controlling a heat pump. Its a 3 ton Grandaire unit and heating about 2500sqft.
Old 01-13-2009, 01:26 PM   #5
there's a step by step manual on the site. Just go thru it and see what you can use. If there is some features that you find confusing post them and we'll see how we can help. You have to know what is important to you for us to expand on any sticking point you might have in operation.
Old 01-13-2009, 01:27 PM   #6
General consensus is to not set your temp back too far or the aux will kick on when recovering.
Old 01-13-2009, 02:10 PM   #7
Rewards Points: 129
Thats the kind of "tribal knowledge" that I'm looking for....do's and don't's kind of info.
The site actually as a simulator for the thermostat. Actually going through the programming isn't hard...the sticking point is what to program into it to make it most efficienct.
Thanks for the replies.
Old 01-13-2009, 02:38 PM   #8
Generally it is set back on days you won't be in the home and then comes up to temp before you come home from work or what ever.
Respect the sixty five degree set back rule: Do not go lower than sixty five for night set back. The recovery time requires more power to com up to comfort set point than is saved by the set back temp setting.
If your back up heat blower is a variable speed or even if it isn't, you can program the blower via the stat to run on low speed to even out the temp in the home.
Whole bunch'a other stuff too but you will have to read the manual to see what might strike your fancy and be of benefit to you.
Programmable t-stat for hot water heat? Ultrarunner2017 HVAC 2 10-22-2008 12:57 PM
Estimated time to Install Underlayment lucknowm Flooring 5 03-06-2008 06:26 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
Time for Painting Second Coat Dougit Painting 1 01-27-2008 09:33 PM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 05:46 PM
