First Time Homebuyer- Heil DC80 Blowing Cold Air - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 11:39 AM   #16
I still haven't had a chance to take much of a look at it, been super busy with work and fixing my work rig. Quick update though... last night I noticed it blowing cold air again, so I pressed "Hold Temp" and turned it way up to 90. The pilot valve lit back up, and then ignited again like normal, all while the fan was still running. Sounds like a thermostat problem to me, can anyone confirm?
Originally Posted by yuri View Post
That one I would get rid of and replace with a Honeywell Focus Pro from HDepot RTH series. The one you have I have replaced a lot of due to age etc. 10 yrs is the average life of any elec stat.
Hmm alright. I kind of thought this one would be a bit older and trouble-prone. Thanks.
Originally Posted by ben's plumbing View Post
that is a honeywell smart valve system.....that valve had problems where ignitor plugs in at valve.....also small port on inducer motor where hose from pressure switch connects clogs ... ben sr
I'll have to take a look at that connection and the small hose. Will post findings when I find those components Thanks a lot
chwkrx7 is offline   Reply With Quote
Old 11-06-2012, 03:00 PM   #17
Problem possibly fixed...
At Yuri's suggestion, I went out and bought a new Honeywell RTH series thermostat. Wiring it was much easier than I anticipated, as my house is only set up for heat (3 wire).
As I was removing the wires from the old stat, the red (Rh) wire, broke off as soon as I touched it. Could a bad connection there be the cause for a fan running but no ignition? I'm hoping so.
Anyways, wired up the new stat and installed it. I turned power back on to the furnace, and the whole system has been working perfectly for the last 16 hours or so.
I'll still take a look at the ignitor plug-in at the smart valve and the small hose that Ben Sr. mentioned.
One more question.. where the ignitor wiring goes into the "box", this should be a very well sealed connection right? I've circled it in red in the picture below. It seems mine isn't sealed very well. If I have to, what should I use to seal the hole the wires pass through?
Thanks again guys,
Dirk
Old 11-06-2012, 03:41 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
I would not worry about that hole. It will draw a tiny bit of air IN thru it to feed to burners which is OK anyway. I don't seal them.
Old 11-06-2012, 06:04 PM   #19
OK. Thanks again for all your help!
Old 11-07-2012, 08:16 AM   #20
Rewards Points: 1,574
I'm looking at the connection of your exhaust pipe from the burner box; is that well sealed? Hard to tell if there is a gap there or not, I thought it would have been PVC??
bob22 is offline   Reply With Quote
Old 11-07-2012, 08:41 AM   #21
Hvac Pro
yuri's Avatar
Actually that is a 4" intake pipe. THat furnace is an oddball/anomaly in our biz as it is the only mid efficiency unit I have seen approved to take outdoor air for combustion. Exhaust pipe attaches to the ventor at the top of the pic. I would seal it to the housing with silver foil tape.
The Following User Says Thank You to yuri For This Useful Post:
bob22 (11-07-2012)
Heat Pump Not Blowing Cold RB101011 HVAC 18 09-29-2011 11:03 PM
Comfortmaker RPJ II blowing only cold air. lse HVAC 3 09-16-2011 07:14 PM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 07:23 AM
First time homebuyer...the 3rd time! BobDuhBuilder Introductions 1 07-11-2009 11:16 PM
Blowing cold air TODD_70 HVAC 1 11-24-2008 08:33 AM
