First Time Furnace Repair. Any Advice? - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 02:33 PM   #76
Originally Posted by hychesee View Post
Too bad this thread took the route the Somalian pirates only take, the high and mighty like to see their opinion in print for no other reason but to be a loud mouth "god save the queen" bully ... <period>. This altruist crap runs like diarrhea. Have fun on your vacation and when you get back go ask for advice on a real help forum and not one where they rub nuts.
Geez ...take it easy you'll have a coronary....
hvaclover is offline   Reply With Quote
Old 10-19-2015, 09:11 AM   #77
Rewards Points: 4
Furnace Repair
late 80s high efficiency natural gas furnace, when switched on the pilot comes on , burners ignite and then the burners go out but pilot stays on
Cgdishong is offline   Reply With Quote
Old 10-19-2015, 12:36 PM   #78
BIGRED
Rewards Points: 252
Turn your thermostat up 10 or 20 degrees from where it is. If the pilot lights and stays on and the main burners light, even for a minute, the furnace is working, but it doesn't have any call for heat. If this doesn't work is your thermostat powered from the furnace wiring or does it have a 'AA' battery inside it ? Basically on a call for heat your stat only gives your furnace a closure like a light switch so you can try crossing the stat "heat" leads to see if the furnace responds with heat.
Gramp Bud
Grampa Bud is offline   Reply With Quote
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Need New furnace advice. Unregistered HVAC 3 10-23-2006 10:13 PM
Furnace repair Bullwiiklesdad HVAC 3 10-19-2006 02:11 PM
