#16 |
HVAC / Plumbing
First time furnace repair. Any advice?
If you have a V M you could check for 110 v at the red terminal on the board on a call for heat..Red from V M to red wire terminal.. black lead from V M to ground or white.. If you have 110 v the fan should run
#17 |
Contact the mfg of any HVAC brand. They'll confirm what I told you.
Controls are not rebuilt for a darn good reason. When a new furnace model is safety certified it is with the components that the mfg hast designed in to it. Any field alterations would be considered a deviation (that means repairing a board or any other part of the safety or ignition system) from the original design and puts the liability squarely on the shoulder of the offending individual. There was a guy around here who was repairing Bryant blower boards some years ago for local wholesaler. UTS shut 'em down hard. And rightfully so. The solid state components were generic and not the same quality the OEM put into to the board. There were a few cases of gas valves not closing on the end of a cycle. I ran those calls and they were the repaired boards I mentioned.
Just slow, not stupid. Last edited by hvaclover; 04-06-2009 at 11:18 PM. |
#18 | |
HVAC / Plumbing
First time furnace repair. Any advice?Quote:
I agree... Wouldn't buy parts off E-Bay either |
#19 |
Glad we agree. Ebay is not the place to buy a part. Whose gonna back up the warranty?
Just slow, not stupid. |
#20 |
Hvac Pro
The other issue no one seems to understand or care about is that a circuit board is a critical safety device. If you mess it up and the flame sensor/flame failure part of it quits you can fill up the furnace/house with gas and voila, first person to turn on a light switch blows up the house. Nothing against some DIY repairs but fixing circuit boards is verboten.
#21 |
Update, got the new control board, it was a breeze to replace. Turned the system on and the fan started just fine. Now, another problem is with the burner, the gas burner turns on for a few seconds and then shuts off. Is this a symptom of a bad pressure switch?
#22 |
HVAC / Plumbing
sounds like flame sensor.. Clean it or make sure it has good connection on the new board
#23 |
First time furnace repair. Any advice? |
#24 |
HVAC / Plumbing
it will be a steel rod that the burner flame burns against as the flame shoots into the chamber.. It's around the burner
#25 |
Right here
#26 |
Got it! Thanks! Cleaning it now
#27 |
Cleaned with sand paper... still no go... system cycles on/off. Anything else?
#28 |
btw, check out the back of my old control board
#29 |
cleaned it a little more... no change
![]() should i order a pressure switch now? |
| Display Modes | |
| Help troubleshooting furnace problem | robert_ | HVAC | 21 | 02-15-2012 09:04 AM |
| first time startup on Bryant furnace - furnace calls for heat and will not stop | luvheat | HVAC | 22 | 02-14-2009 09:56 AM |
| Oil furnace does not fire up | sbhavinm | HVAC | 5 | 01-17-2009 08:06 AM |
| Need New furnace advice. | Unregistered | HVAC | 3 | 10-23-2006 10:13 PM |
| Furnace repair | Bullwiiklesdad | HVAC | 3 | 10-19-2006 02:11 PM |
