#1 |
First replacement unit R22 to R410A high efficiency
What are the requirements to replace a R22 unit to R410A unit?
Do I have to change the linesets or just need flush? Any restriction on working with high pressure? The new unit has the same ton so I do not need a new load calculation right? The linesets are 3/8" and 3/4 and the unit has 3/4 and 7/8. I just need adapters, dryer filter etc Thanks Yall
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead. |
#2 | |
An old Tradesmen
First replacement unit R22 to R410A high efficiencyQuote:
#3 |
I use Silver 15% rod.
The customer is not complaining about the performance of the old unit. I'm just thinking in advance. What size line set do the install instructions say to use. what happens If I already have the line set installed?
#4 |
An old Tradesmen
Kind of depends on the size the manufacturer said to use, and the length.
#5 |
Did you leave the old evap coil or replace it?
#6 |
I'm going to replace everything. I'm trying to keep only line set.
#7 |
No flush is needed on the line set, but it must be sized correct
#8 | |
I thought I got a problem with the oil used on R410A to be different of R22. This is the reason we need to flush to clean the oil contamination from R22. Can you explain better this sized correct?
#9 |
( You need to install the CORRECT LINE SIZE that the mfg has spec'd )
#10 |
Hvac Pro
You DO need to flush it. Read those install manuals I gave you links for. There is a product called Rx-11 flush also. Expensive but works REAL well.
http://www.nucalgon.com/products/tot..._rx11flush.htm
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 | |
#12 |
The idea is to install the new high efficient system that fit the lineset already installed. If I need to change the lineset. it's gonna be a lot construction work. I don't think the costumer wanna destroy his floor.
#13 | |
#14 |
An old Tradesmen
Post the size of the lines set and the size of the unit.
#15 |
Hvac Pro
Yes you do according to Lennox. It gets down to a matter of professionalism and whether a guy wants to spend the time and $$ to do the job to what he considers a professional job. Some guys flow nitrogen when welding others don`t. My company has LONG term customers so we don`t want contaminated systems and premature failures if possible and are willing to go the extra mile to keep the system clean. Lots of guys are to cheap to install filter driers, low ambiant controls or even pull a deep vacuum. We can debate semantics forever.
| Display Modes | |
| high efficiency furnace exhaust pointing upward? | flyorange | HVAC | 10 | 01-07-2011 11:18 PM |
| New High Efficiency Furnace Problem | Buster 567 | HVAC | 8 | 12-13-2010 09:36 PM |
| high efficiency gas furnace | hammer6315 | General Discussion | 2 | 06-18-2008 11:25 PM |
| New High Efficiency Gas Furnace & Hot Water Heater | frank08226 | HVAC | 2 | 04-17-2008 01:06 PM |
| Heil High Efficiency 5000 | boman47k | HVAC | 5 | 12-14-2007 02:05 PM |
