Old 10-05-2008, 09:45 AM   #16
Old Guy!
First Furnace Install - Need Some Help Getting Started
Originally Posted by hvaclover View Post
I'll email the moderators and tell them to expect him
IP noted
ROTFLMAO! Fancy meeting you here!
Oh yea, we're ready and waiting! LOL
HeyBob is offline   Reply With Quote
Old 10-05-2008, 10:19 AM   #17
oops, did I do that!
A plenum is usualy the first piece of metal on the outlet of the furnace, the trunkline is any ductwork that follows.
If you are using a horizontal built up air handler, you may not need a plenum, the main trunk screws directly on the air handler discharge opening.
Establishing a consistent pressure and smooth, uniform flow is what needs to be focused on, plenums are sized for and used to establish both, so that distribution of the air can be predictable.
8 Ball is offline   Reply With Quote
Old 10-11-2008, 12:55 PM   #18
An old Tradesmen
6" flex, will give you a high static pressure, if you try to move 100 CFM through it.
You may be looking a duct sizers that are intended for use for sheet metal.
You may be confusing static pressure and friction rate.
They are not the same thing, and that misconception, has harmed more furnaces then not.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 04:57 PM
furnace install michael cook HVAC 7 03-13-2007 08:49 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
