First Company Hw System - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 11:33 AM   #1
first company hw system
I have a first company hot water furnace. when the unit calls for heat the blower comes on right away which blows accross the unheated coils. during the winter months I kill power to the heat pump which causes the boiler to fire as aux heat. it seems that i need to run the t-stat up by three degrees above setpoint to make the air feel warm. I am also interested in changing the blower speed and am confused as to which wires to move.
Craig
craigcorum is offline   Reply With Quote
Old 12-12-2009, 02:25 PM   #2
An old Tradesmen
Rewards Points: 6,072
Cost you less to heat if you leave the heat pump on.
Should be a wiring diagram on the panel that shows what wires to change.
Old 12-13-2009, 03:29 PM   #3
Originally Posted by beenthere View Post
Cost you less to heat if you leave the heat pump on. I am aware of that but the wife likes the feel of the hydronic heat. It worked well the first two seasons but this season the problem has come up with needing to set the t-stat up by three degrees in order to throw the system into the aux mode which in turn brings the temp from 70 to 100 degrees through the coils
there is a wiring diagram but it is most confusing. there are four wires coming off the fan, black connected to the high post on the circuit board, blue connected the low post, red to the spare post and of course white to load. the diagram calls for different colors and is therefore hard to absorb. it does however suggest that black is high, blue is med and red is low....but on which posts. your help is appreciated
Craig
Old 12-13-2009, 04:37 PM   #4
Rewards Points: 502
Craig
Instead of killing power to heat pump, sounds like you need to just set your t-stat to aux heat...that should solve the need to bump the t-stat up 3 degrees, which causes the t-stat to energize the aux heat relay.
Without a picture or schematic, it'll be hard to tell you what wires to move where. As was previously said, you'll need to read thru the schematic.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Tags
blower speeds , first company
new system install.....questions firedogut HVAC 4 10-04-2009 08:10 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 11:06 PM
