Fireproof Concrete/patching Material For Woodstoves? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 08:31 AM   #1
the Musigician
DangerMouse's Avatar
fireproof concrete/patching material for woodstoves?
ok, here's one for you fireplace/woodstove guys. i have a real old woodstove that has the inner fireproof cement liner deteriorating. is there a mixable powder product i can use to refill the gaps?
tnkx!
DM
Old 09-09-2008, 09:11 AM   #2
Whatamess
Yes there is and Lowes use to carry it. I believe it is called firecrete. But I am not sure.
http://www.selleys.com.au/Selleys-Fi...t/default.aspx
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-09-2008, 10:39 AM   #3
47_47's Avatar
Rewards Points: 50
Furnace cement, most well equiped hardware stores will have it.
47_47 is offline   Reply With Quote
Old 09-10-2008, 07:49 AM   #4
Years ago I had a Jotul Model Number 1 with a cement liner that had broken off near the door. It was a 3" by 8" piece. I used furnace cement to re-glue. It worked well and never came lose, but I did not use the stove extensively so cannot be sure how well it held up. I sold the stove 2 years ago.
I am not sure you can use the cement to seal cracks. Unless you are sure you have the right product, it might be worth a trip to a wood stove outlet store. You will pay more, but can be sure you'll get the right product.
Wood stoves are great, but not worth burning down your house. I'll never forget Christmas Day '05 watching helplessly as the first spreads across my neighbors roof. Cause, yep - a wood stove. Waiting for our awesome volunteer fire department to arrive was the longest 10 minutes.
dac122 is offline   Reply With Quote
Old 09-10-2008, 08:02 AM   #5
the Musigician
you are right there dac, i ended up buying a 1/2 gallon tub of 'refractory cement' for repairing firebrick. this is what i believe i needed, the furnace cement says for brick to metal or metal to metal, so i wasn't sure if it would do what i needed. just a follow up so you guys know what i ended up with. though this stuff says i need to apply no more than 1/8" at a time, we don't NEED the woodstove yet, so i can layer it till flat. cool! thanks for your responses and helping steer me in the right direction.
DM
Old 09-10-2008, 02:01 PM   #6
Rewards Points: 270
i almost hate to ask (about such a tragedy) but do you know the specific cause - chimney fire - creosote? or from burning a bunch of Christmas wrap / packaging? old / outdated / substandard flue components? over-fired stove box?
not trying to dredge up bad memories, but I too love the wood stove, and if there's a specific thing here to drill into our heads about this, it could save another family from the same fate...
rtoni is offline   Reply With Quote
Old 09-10-2008, 02:13 PM   #7
The report I got from another neighbor was a pin hole in the double wall lined pipe where it passed through the roof. Obviously not related to this situation, but just wanted to impart how careful one should be with repairs. We always think wood stove fires happen to the other guy.
I might suggest to the OP to check your work after firing the stove the first time.
Old 09-10-2008, 02:49 PM   #8
Rewards Points: 270
...just wanted to impart how careful one should be with repairs. We always think wood stove fires happen to the other guy.
amen on that one
a pin hole in the pipe - wow - thanks for the add'l info...
Old 09-10-2008, 02:52 PM   #9
the Musigician
no problems here as the work is inside the woodstove. just cracks and wear and tear on the liner is all. first coating all done and it seems to be fine. no work on the chimney/flue except the cleaning yesterday. =o)
DM
Old 09-12-2008, 08:44 PM   #10
Electrician
SD515's Avatar
Rewards Points: 504
DM
Such a fun job, isn't it
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
Material to use for replacing linoleum (glued down). spookercat Flooring 2 06-25-2008 11:51 PM
Non-Slip Material dolver Interior Decorating 1 07-05-2007 07:57 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 07:30 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
