Fireplace Odor - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 02:05 PM   #1
Fireplace Odor
I have a fireplace that occasionally produces a musty, burnt ash smell in the house when not being used. This odor seems to be random, occurring during dry or humid weather, and without regard to whether the fireplace has ashes in it or not. The fireplace is on the main floor, is a conventional insert w/metal chimney and is the only fireplace in the house. The chimney draws well when I have a fire. Any ideas as to what causes the odor?
pgr380 is offline   Reply With Quote
Old 02-28-2009, 02:46 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,132
Downdraft/negative pressure in the house. Changes in weather/barometric pressure etc can cause that. There is always leftover residue in the chimney and with a downdraft that may be the smell. If you can catch it at the right time blow some cigarette smoke in and see if it rises/and open a window nearby.
Old 02-28-2009, 04:35 PM   #3
I have the same thing happen every now & then
Usually on windy days
Old 02-28-2009, 09:05 PM   #4
Makes sense. I can turn on the gas lighter and the odor goes away. I suppose it heats up the fireplace and reverses the air flow. It's just that I can't keep it lit all the time.
Old 02-28-2009, 09:36 PM   #5
Hvac Pro
yuri's Avatar
I have seen a few "Heatilator" more efficient/airtight types where they have good sealing front doors. The combustion air comes in under the grate thru 2" pipes from the outside. Maybe they are available in your area.
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
