Fireplace Not Starting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 07:12 PM   #1
Fireplace not starting
Somehow my fireplace is not starting ...looks like it has auto pilot but still it doesn't start when I switch on the fireplace switch Any thoughts about this Please help
karsat is offline   Reply With Quote
Old 01-19-2012, 07:43 PM   #2
btw its heatilator
Old 01-19-2012, 08:01 PM   #3
Rewards Points: 13,300
Has it been started this year?
Is this a new fireplace?
100% sure there's gas in the tank?
Is there pilot flame?
Old 01-19-2012, 08:06 PM   #4
how
Rewards Points: 1,102
Most of the time it's a pilot thats dirty and not enveloping the powerpile well enough to power the gas valve....And... All the wire connections on the gas valve and the fireplace switch need to be completely tight for the unit to work.
how is offline   Reply With Quote
Old 01-19-2012, 08:08 PM   #5
What furnace switch? It's a gas fire place?
Old 01-19-2012, 08:26 PM   #6
Its a gas furnace it hasnt been started this year I dont know about furnace switch I opened hte panel but couldnt find what you are referring about I don't think it needs gas from tank looks like its connected to gas line I suspect its pilot but dont know how to fix it
Old 01-19-2012, 08:35 PM   #7
how
I was responding to it as a fireplace that the posted heading implied. Ignore my post about the fireplace advise..
Give us the rough age/ brand & model of your furnace.
Old 01-19-2012, 08:38 PM   #8
its 3 year old Heatilator brand....where to look formodel number?
Old 01-19-2012, 08:44 PM   #9
I'm Your Huckleberry
Rewards Points: 2,270
The cause.
Troubleshooting.
http://www.youtube.com/watch?v=n1ki2...eature=related
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-19-2012, 08:55 PM   #10
Thanks for the video but still Im not able to figure out the solution
Old 01-19-2012, 09:14 PM   #11
That second video should be disregarded. I posted it in haste thinking it was a pro but after actually watching it I realized it was not.
Do you have a standing pilot light that is always lit?
Thanks.
Old 01-19-2012, 09:15 PM   #12
I don't see any lighting all the time its not like a gas water heating furnace
Old 01-19-2012, 09:20 PM   #13
model CD4842I4
Old 01-19-2012, 09:38 PM   #14
I see the sparks also in the fireplace somehow it still doesnt start
Old 01-19-2012, 10:21 PM   #15
how
For most fireplaces (that Spark when the pilot is being lit) you need to first turn the control on the gas valve to the "pilot" position. When it's in the pilot position, that same contol should then be depressed while pushing in the igniter button. Try this for a minute and then STOP.
If it's been off for a long time you may first need to purge the air out of the gas line before the pilot will actually light. I can't figure out a way of telling you how to do this that is safe enough for a public forum like this.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
