Fireplace Insert - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 10:38 PM   #1
Fireplace Insert
Hi guys, so I'm doing a complete renovation on my new home and its finally time to start working on the fireplace.
Apparently the vent fan in the firebox insert has "never worked" according to the previous owner. I have checked the power line and it has power but I'm guessing the motor is just dead?
How difficult is it to replace the insert? I had someone tell me that it might not be possible since it is not a masonry chimney and would require the chimney to be demolished and rebuilt.
CMB00 is offline   Reply With Quote
Old 02-09-2013, 08:50 AM   #2
Rewards Points: 1,294
So, you want to replace the whoe fireplace because the blower does not work? Or is the original plan to replace the fireplace anyway. If the issue is just the blower motor, they can be purchased at almost any heating supply house. Grainger sells them as well. Did one not too long ago and the motor was about $75.00
danpik is offline   Reply With Quote
Old 02-09-2013, 09:55 AM   #3
Civil Engineer
Rewards Points: 4,560
You did not indicate where you live. In my town, and in many locations, installation of a fireplace insert or wood stove requires very careful attention to the chimney. When I put my wood burning insert in, code required that I have a stainless steel insert inside my flue lined brick chimney. If I had not had a brick chimney, I believe my installation would have required double or possibly triple walled stainless steel pipe.
You need to check with your local building inspector, they will tell you the rules. As a note, I do a lot of DIY, but not the stainless chimney, requires you to get on the roof, push the liner through and connect, not something I cared to deal with.
Old 02-09-2013, 11:36 AM   #4
Roofmaster
Rewards Points: 2,172
From the looks of what you have there, I would rip all of that out and start over. It looks like an accident looking for a place to happen. I would never never never have wood frame construction that close to and above a heating appliance. Use metal studs when you re-build.
Old 02-09-2013, 11:37 PM   #5
I would like to avoid replacing the entire unit. Are these motors pretty much universal or will i need to find out what model of insert i have?
Old 02-09-2013, 11:39 PM   #6
I live in Northern Virginia, the chimney construction is fine. Just had most of it rebuilt and had it inspected. I just want to find out how to get the blower working again before I do anything else.
Old 02-10-2013, 01:11 AM   #7
Rewards Points: 13,250
Going to have to pull the motor out to read the tag on it.
Old 02-11-2013, 12:05 PM   #8
Special User
Rewards Points: 1,230
While you're at it, check the model number of the fireplace insert itself to make sure it's a "zero clearance" to combustibles model. The wood framing still worries me...
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 02-11-2013, 02:18 PM   #9
How do you get to the motor? Is it on the top, bottom?
Is it possible to just remove the insert and build a brick firebox?
Old 02-11-2013, 11:27 PM   #10
Nevermind, i found out the issue with the blower was a faulty wall switch. Very very good news! Thank you all for your help!
Fireplace insert vs heatilator marriedmanw Concrete, Stone & Masonry 7 10-23-2012 12:36 AM
insulating around a fireplace insert hellonoko Insulation 1 03-05-2012 08:49 AM
Fireplace Insert Chimney Liner installation eric859 HVAC 11 03-04-2011 04:58 PM
Installing a fireplace insert in older home. Fixitgeorge Remodeling 4 02-02-2011 11:09 AM
Cold Air Coming In From Bottom/Underneath of Gas Fireplace Insert mark2741 HVAC 7 12-10-2010 10:05 PM
