Fireplace Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 02:30 PM   #1
Fireplace flue
have a gas fireplace on the 1st floor of a 2 story complex. The condo was built in the 70's. The flue runs within the walls on the inside of the house. Have noticed the walls get pretty hot in the bedroom above the fireplace where it appears the flue runs thru on its way to the roof.
Aside from opening the wall, can I run something within the existing flue to better insulate it? Is this a serious flaw or danger?
thanks, Curtis
curtis_n94521 is offline   Reply With Quote
Old 01-17-2010, 03:21 PM   #2
Remodeling Contractor
Dangerous to mess with a flue lining. 2" space needs to remain around it. No holes even tiny ones are allowed. Since these will leak toxic fumes into the house.
Old 01-18-2010, 11:40 AM   #3
What should have been installed is class B vent chimney pipe. It is double walled pipe with a positive lock between each segment, with special thimbles when passing though combustible materials, etc. Depending on the brand of pipe you can have 1" clearance to combustibles or greater. You local codes may have stricter overrides than that clearance and require other things.
I too would be a little concerned about that. If you have never had the stove checked out I suggest having someone qualified check out its operations and check the install. It will most likely require pulling the stove to verify if the install was done right, and up to code.
dac122 is offline   Reply With Quote
Old 01-18-2010, 02:45 PM   #4
re: Fireplace Flue
Agreed... thanks for your advice.
Old 01-18-2010, 03:46 PM   #5
wall should not be hot to touch
Fireplace insert flue closure air-tightness fishmanflats HVAC 7 12-21-2008 06:19 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
