Old 12-27-2012, 11:28 PM   #1
Fireplace and Double Wall B Vent
I'm replacing a gas fireplace that is vented with double wall B vent. The new fireplace is slightly shorter than the previous one, so where the connection is made to the fireplace the inner corrugated ducting can reach and be connected but the outer wall (the solid sheet metal) is about an inch short. Can I get away with this or do I have to get a new piece of duct.
Duddy is offline   Reply With Quote
Old 12-27-2012, 11:42 PM   #2
hi sometimes they make an adjustable connector , if its made to be operated with double wall type b vent ,,, you should use it right back to stove for saftey reasons ,, you shouldnt deviate from mfgs installation parameters
hvac dude is offline   Reply With Quote
The Following User Says Thank You to hvac dude For This Useful Post:
Duddy (12-27-2012)
Old 12-27-2012, 11:45 PM   #3
istallation instructions tell all
Old 12-28-2012, 07:03 AM   #4
No you can not get away with it. Keep it double wall all the way.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-28-2012, 07:27 AM   #5
keep it double wall ...don't cut any cornors on this install not worth a fire???ben sr
Old 12-28-2012, 02:48 PM   #6
An old Tradesmen
Can you post a pic of the vent. B vent flexible connector is corrugated. But B vent itself isn't.
The Following User Says Thank You to beenthere For This Useful Post:
carmon (12-28-2012)
Tags
double wall b vent, gas fireplace, hvac
I Need A Double Sided Fireplace ddawg16 HVAC 0 07-14-2012 02:15 AM
gas water heater vent into furnace vent??? Master Brian HVAC 2 05-08-2011 01:16 PM
Fireplace Heatilator and wood burning insert mmadden68 HVAC 5 03-29-2011 12:13 PM
Hanging a joist in an 1895 brick wall billydwilliams Building & Construction 4 03-28-2011 04:09 PM
Direct Vent or Free Gas Fireplace rocketdoctor HVAC 1 04-12-2009 07:47 AM
