Fireplace Blower Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 11:48 AM   #1
P Marage's Avatar
Rewards Points: 87
Fireplace blower installation
I was just given a blower for my fireplace but have a couple questions.
I dont quite understand the wiring diagram for the fireplace but to my untrained abillity to read the diagram there appears to be a place I can wire the blower to the control mechanism.
I have included a copy of the diagram and the Control mech, If anyone could help me figure out the wiring diagram so I can put sense to the control mech.
Im looking at "B3" as a potential power source, beside it has a triangle with a 4 inside it that says air circulation fan..
P Marage is offline   Reply With Quote
Old 02-06-2011, 11:57 AM   #2
Experienced
Jackofall1's Avatar
Looking at the available information, you don't have a 110 V power source there yet.
Mark
Old 02-06-2011, 12:02 PM   #3
P Marage's Avatar
Rewards Points: 87
Thanx Jackofall1, The fireplace is on a wall switch. I will tap in to that for the fan if I need to, but Can I tap directly to the power that supplies the control mechanism shortening the distance I need to travel for power? after all Isn't the wall switch what supplies the control mech.
Old 02-06-2011, 12:17 PM   #4
Experienced
Jackofall1's Avatar
Is there 120V at TPTH and TH?
If there is there is no reason you can't connect the fan there.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
P Marage (02-06-2011)
Old 02-06-2011, 12:50 PM   #5
P Marage's Avatar
Rewards Points: 87
There appears to be no power at the TPTH and TH. I even pulled the cover plate at the switch and no power there. I hit it with my ohm meter and its just an open/close port, I tested every terminal on my control mechanism and I cant find any source of power although the leads all read open(ohms). Now im confused. Apparently my fireplace draws power from the very air around it. lol. my multi meter is working correctly (did wall test) Final option will be to run a power cable to the nearest plugin.
Old 02-06-2011, 12:52 PM   #6
Experienced
Jackofall1's Avatar
Does your fireplace work?
Without power on the gas valve how would it open?
Breaker tripped or off?
Mark
Old 02-06-2011, 01:06 PM   #7
P Marage's Avatar
Rewards Points: 87
This is where Im confused because it does work. I have easy access under where the control mech is and I tested every wire under the FP but can not find a source of power. I have checked for an opening under the fireplace hoping that when they installed it there was a power box in the mantel but cant find any access. There HAS to be power to the system I know that, but its eluding me.
Old 02-06-2011, 01:09 PM   #8
P Marage's Avatar
Rewards Points: 87
Can the Thermopile produce enough power to open and close the valve? It produces Millivolts which might explain why my multi meter wont get a reading.
Old 02-06-2011, 02:52 PM   #9
Experienced
Jackofall1's Avatar
Yes the thermophile can generate the power to open the valve, this is why I responded as I did with the first post, but when I went back to look at the picture the thermophile is not on the same terminals as the drawing indicates they should be.
The wire connected to that valve look like 14-2, which would indicate 120V.
Guess more investigation is required.
Mark
Old 02-06-2011, 02:53 PM   #10
Experienced
Jackofall1's Avatar
Can you get the model # and manufacturer off the valve?
Old 02-06-2011, 03:09 PM   #11
P Marage's Avatar
Rewards Points: 87
heres the tag.
Btw thanx for your help Jack
Old 02-06-2011, 03:24 PM   #12
Experienced
Jackofall1's Avatar
Well there is your answer to power, right on the tag, valve is for millivolt application.
Now that would mean you will have to run a 120V line over for the fan.
Question --- is the wire on that valve 14-2? or is that your thermophile?
Does this look familiar - http://www.woodmanspartsplus.com/571...va-Valves.html
Mark
Old 02-06-2011, 03:41 PM   #13
Experienced
Jackofall1's Avatar
You actually have a thermocouple not a thermophile
The wires connected to the terminal should go to a switch and could be used for a fan, now all you have to do is find out why that switch on the wall isn't working.
And if the switch on the wall isn't working how do you start your fireplace? --- just turn the valve on?
Some more info --- http://docs.homeclick.com/PE-Links/K...30-install.pdf
Old 02-06-2011, 03:41 PM   #14
P Marage's Avatar
Rewards Points: 87
Yes I figured that out when I saw it says millivolt system only as well. Im not sure what you mean 14-2. (gauge?)
But heres what I can tell you . The wires that are plugged in to the left of the unit exit the fireplace, and the wall switch wires are Identical to those attached to the unit(photo 2, black to TPTH, white to TH). There are 2 other wires that feed directly up into the middle of the fireplace(white) both insulated lines, im assuming one is for the thermocouple, and the other is igniter. one is plugged in right behind the black TPTH line(thermocouple?). and one ground lead to the bottom floor below the regulator.
Old 02-06-2011, 03:43 PM   #15
Experienced
Jackofall1's Avatar
Yes look at the last link I sent you, now all you have to do is figure out why the switch isn't working.
Mark
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Heatilator EC36 Fireplace - Blower location? hartkem HVAC 0 01-15-2011 10:20 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Can I disconnect a gas fireplace blower? davidm Electrical 2 10-03-2009 09:58 AM
Installing Dimmer for fireplace blower MountainMan HVAC 4 07-03-2008 12:09 AM
