Old 06-22-2012, 02:08 PM   #1
fire place pipe
Our house has a fireplace but instead of a brick chimney it has a stove pipe which needs replacing. It's a nine inch pipe. Non of the stove installers want to touch the project. I have found a 9 to 8 in and a 9 to 10 inch collar on line (Selkirk 304-Alloy Heat-Fab Saf-T Increaser - 9 inch to 10 inch) but I need to know the correct pipe to buy to go up through the ceiling, attack and roof. Will a FMI 36 Inch High Temperature Double-Wall Wood-Burning Chimney Pipe Length - 8 Inch Inner Diameter be code?
Thank you for any help.
debd is offline   Reply With Quote
Old 06-23-2012, 02:26 AM   #2
fire place pipe
Why do none of your local installers want to handle the project?
hvac benny is offline   Reply With Quote
Old 06-23-2012, 08:39 PM   #3
fire place pipe
Wish I new. They just shake their heads and say they don't want to get into it. It's a question of going from an old pipe, a nine inch one, and attaching a new pipe which is 8 inch. Granted its been difficult to find the connector part but we finally have.
Old 06-23-2012, 09:42 PM   #4
An old Tradesmen
fire place pipe
pipe and increaser must be from same manufacturer.
Remodeling fire place mantle (lots of pics) supermech21 Remodeling 7 04-02-2012 09:42 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Using flexible pipe for fire pit simonedery Building & Construction 0 07-16-2011 12:01 PM
Gas fire place jimmoski General Discussion 1 02-09-2011 07:10 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
