Finned-tube Elements For Hot Water Baseboard Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2008, 05:49 PM   #1
Finned-tube elements for hot water baseboard heat
I recently refurbished a house about a year ago. I had cleaned the fined-tube elements of my basboards due the amount of grunge on them (they're easily in the 40 years-old range). I used a light solution of Dirtex which did a remarkable job, considering. Last year when running the heat everything was fine. This year I have noticed that each time the boiler goes on, and the lines are flush with hot water, as the elements heat up a rather pungent odor is "released".
My question is two-fold - first, is there a proper cleaner that I can use to cleaned the finned-tube elements? Second, can I paint the finned-tube elements themselves. say with an enamel based paint? I am not talking about the baseboards, but the actual elements - the piping and fins?
I have not measured the temperature that the elements heat up to, so I am not sure, given that I can paint them, if a high-heat paint would be needed.
Any guidence or assistance would be very helpful.
Thanks in advance!
SureBert is offline   Reply With Quote
Old 12-05-2008, 05:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Adding paint is like adding insulation to them. It will reduce the heat transfer rate/efficiency. Bare copper is the best. Try rinsing them with fresh water to get rid of the solvent.
Old 12-05-2008, 06:01 PM   #3
Gee, that (rinsing with fresh water) sounds too simple for me to have even thought of. Thanks for the quick reply! Guess I'm always looking for the hardest way to do anything. I had however thought of the issue of painting them resulting in a reduction of the heat induction.
I will take your advice and give them a good rinsing. THANKS AGAIN!
Tags
baseboards , finned-tube elements , heat
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 07:15 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Baseboard Hot Water radiators hotdiggitydog HVAC 2 04-25-2006 12:27 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
