Finished Basement Heating/cooling? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2008, 07:28 PM   #1
Rewards Points: 12
finished basement heating/cooling?
I'm finishing of my basement and need some advcie on running the air ducts. I did some searching but didn't find alot of info on this. What is the best way to run the heat ducts and cold air returns? Where do you recomend putting the vents, in the wall or ceiling, where on the walls or ceiling? Any info you can share or links to articles to read will be greatly appreciated. Thanks
ponch37300 is offline   Reply With Quote
Old 02-12-2008, 02:46 PM   #2
Rewards Points: 12
Any advice on basement heat and cold air ducts? Any help or links for stuff to read or recomended books will be greatly appreciated. I did alot of searching and i didn't find much as to what size ducts to run and where the vents should go. Thanks for sharing any advice on this.
Old 02-12-2008, 05:05 PM   #3
Rewards Points: 270
A little more info. Where is your AHU?
pcampbell is offline   Reply With Quote
Old 02-12-2008, 06:33 PM   #4
Rewards Points: 12
sorry i'm not familiar with all the terms. Is AHU, air heating unit? If so it is in the basement, almost in the middle. I will have a full bath, bedroom(about 12x20'), and a long family room(about 15x25-30'). The family room runs the length of the house and the bedroom/bath run next to it. hopefully this helps a little. Thanks for any advice.
Old 02-17-2008, 12:29 PM   #5
Real basic: Cold air returns should be near the floor in a wall. Heat supply vent in ceiling would be cake for basements with drop ceiling.
raam is offline   Reply With Quote
Old 02-18-2008, 02:27 PM   #6
Rewards Points: 12
Thanks raam. is there any way to determine how many i will need based on the size of the room? Also how do i determine what size the ducts should be? Thanks
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 04:01 PM
New poster, looking for advise on heating cooling in basement that is being finished blthomas HVAC 11 12-07-2007 11:07 AM
Finished Basement Remodel Questions bioguy Remodeling 6 11-15-2007 10:56 PM
Installing Registers in finished basement boinger HVAC 2 02-07-2007 04:44 PM
