Finding Out The Horsepower - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 01:43 PM   #1
Finding out the horsepower
have a goodmanck36-1 airconditioner . need to replace the screaming fan motor out side and have to know the horse power on the part number 7090-25-0439 I got the rpm number 1075 the hz 60ph1 the v230/208 dont know hwere the horse power number is ...
miss mary is offline   Reply With Quote
Old 06-06-2012, 01:51 PM   #2
1/6 hp?
See pg. 2 of
http://www.myplanet.net/acdinc/ckspecs.pdf
Whatever motor you get has to be rated to run in the very hot air that comes out of the compressor.
Old 06-06-2012, 02:04 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You would be best served trying to get the exact same motor. Don't forget that not all motors mount the same. You can't just get any motor with the same voltage and HP.
The Following User Says Thank You to k_buz For This Useful Post:
Code05 (06-06-2012)
Old 06-06-2012, 02:16 PM   #4
Code05's Avatar
Rewards Points: 1,104
Can you post a picture of the nameplate on the motor?
Code05 is offline   Reply With Quote
Old 06-06-2012, 04:10 PM   #5
You also need the same direction of rotation, shaft diameter, shaft length, etc., etc.. Penetrating oil may temporarily stop the screaming.
A universal replacement motor may cost as little as 1/8th that of an exact replacement, but electrical parts are not returnable and for this money savings you may get considerable uncertainty as to whether the universal motor may work or even how to hook it up.
The last time I did this Grainger did not have a motor that was even close, so the decision to go with an exact replacement was made for me.
If you measure the winding resistances of both the old and the new motor, before replacing, it will give you some measure of assurance.
Old 06-06-2012, 04:39 PM   #6
An old Tradesmen
Rewards Points: 7,256
Moved to HVAC forum.
horsepower vs torque av-geek Tractors & Mowers 1 06-04-2012 08:17 AM
Finding a Structural Engineer for retaining walls CplDevilDog Building & Construction 0 05-02-2011 09:44 AM
Finding wall studs jmfma General DIY Discussions 8 01-03-2010 05:06 PM
Finding a wire behind drywall hogger9 Drywall & Plaster 8 02-06-2009 04:42 PM
6 horsepower redline General DIY Discussions 1 05-31-2008 04:20 PM
