Finding Gas Pilot Light To Old Wall Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2013, 06:59 PM   #1
Finding Gas Pilot Light to Old Wall Furnace
Hi, I want to turn off my gas because of hotter outdoor temperatures, but I can't figure out my Lennox wall furnace.
*Picture attached. I've put a red circle around what I think is the pilot light. It has no ON/OFF markings and, regardless of moving it clockwise or counter-clockwise, nothing seems to change.
Any idea how I can shut the gas off on this puppy? Thank you.
Bill T. is offline   Reply With Quote
Old 07-01-2013, 04:34 AM   #2
An old Tradesmen
Rewards Points: 7,832
Moved to HVAC forum.
Old 07-01-2013, 08:13 AM   #3
Rewards Points: 6,652
Follow the incoming gas piping. Is this on a slab, or on a crawlspace? The shutoff should be on the left. That unit does need a good vacuuming to get rid of all those cobwebs. Looks like it has not been touched in years, so makes for a good CO emitter.
The Following User Says Thank You to gregzoll For This Useful Post:
digitalplumber (07-01-2013)
Old 07-01-2013, 03:11 PM   #4
FClef's Avatar
Rewards Points: 160
Yeah, that unit looks in rough shape. Best to get it serviced and inspected for any cracks in the heat exchanger.
FClef is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Carrier Furnace (1985) No Pilot tlc4dna HVAC 8 12-09-2011 08:52 PM
Williams NG furnace pilot light will not stay lit zBernie HVAC 1 12-04-2011 10:06 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
