Filtrete Furnace Filters - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 03:40 PM   #1
Dave Sal's Avatar
Rewards Points: 662
Filtrete furnace filters
Hey guys,
I normally use the red Filtrete furnace filters with a 1000 efficiency rating. Unfortunately, last week when I went to buy one the hardware store was out of stock and all they had were the higher 1500 version, which I purchased. I seem to remember reading something about how furnace filters can actually be too restrictive and not good for the furnace. I have a Lennox G60 two stage furnace with a Lennox ACX a/c unit. I usually change my filters every three months. Any problems using this more restrictive filter? Thanks
Dave Sal is offline   Reply With Quote
Old 08-25-2013, 03:53 PM   #2
An old Tradesmen
Rewards Points: 7,268
Change the 1500 every 30 days, at least.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (08-26-2013)
Old 08-25-2013, 05:26 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
You should do a temp rise test thru the furnace when running on both stages or have a Pro do it. I have seen units run just fine on the lower grade filter and start overheating and cycling on the limit control by going up one grade higher of filter. Mostly has to do with poor undersized ductwork which we cannot assess over the net. I dislike filtr*etes anyway as the industry standard uses MERV rating. Use a Merv 7 or 8 True Blue from HDepot and you probably will be fine.
The Following User Says Thank You to yuri For This Useful Post:
Old 08-25-2013, 10:42 PM   #4
Dave Sal's Avatar
Rewards Points: 662
From what you said it sounds like this might be an issue during the heating season. I'm not going to take a chance, so I'll change it next month and then go find my regular filter, or I'll stop by Home Depot and check out the True Blue filters. Thanks for the replies guys.
Old 08-27-2013, 03:53 PM   #5
Just by way of an add-on, I would suggest having a tatice check done on the duct system even though you go with a Merv 7 or 8 filter.
There was a lot of misinformation among home owners concerning the how restrictive these Filtrete filters really are, thsnks to the Big Box companies.
Any way, a little extra margin of safety would not hurt. The static test would afford this to the HO.
hvac5646 is offline   Reply With Quote
old furnace with bizarre filter setup utek HVAC 2 10-14-2013 08:49 PM
tiling under new furnace gramps416 Flooring 4 01-09-2011 10:47 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
furnace filters eager2lern HVAC 2 12-03-2006 08:52 PM
