Filter Vs. Whole House Cleaner? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 04:40 PM   #1
Rewards Points: 18
Filter vs. Whole House Cleaner?
I have severe allergies/asthma and my wife and I just moved into a new place a few months ago. A neighbor burns a wood fireplace often in the winter and the smell was coming into our home badly. I invested in a 3M Filtrete 1900 Ultimate Allergen Reduction filter to go onto the York furnace installed in our new home. The air filter has helped the problem a ton. On the worst nights (where it's foggy and smoke sits still outside) it still smells inside some, but not nearly as bad as before. I have a local contractor who I asked about reducing smoke smell and just allergies in general who recommended a whole house cleaner to be installed on the furnace.
The recommended whole house cleaner is a York Affinity Media Filter (MERV 13). It costs $450 to install. My question for you is: how much more effective at stopping smoke smells and reducing allergens would the whole house cleaner be vs. just keeping the 3M Filtrete 1900 filter that is now on the furnace? Trying to decide if it is worth my money to put the whole house cleaner on. If it will help allergies/asthma I'm willing to pay for it, just want to be sure it's a big upgrade. Thanks for your input in advance!
Aaron
02SmithA is offline   Reply With Quote
Old 02-07-2013, 04:51 PM   #2
MarginallyQualified
Rewards Points: 2,464
...the smell was coming into our home badly.
Do you make some sort of association between allergies and smoke odor?
Before the annoying smoke odor issue presented itself...
what plans did you have for the house regarding your allergies?
Old 02-07-2013, 05:58 PM   #3
Rewards Points: 18
Yeah I have asthma caused by the allergies.. and the single biggest trigger to my asthma is the smoke odor.
The home is brand new so it is very tightly built, but we have three air purifiers running at all times (bedroom, office, and living room) they definitely help, but I'm trying to improve the air quality even more.
Old 02-07-2013, 06:07 PM   #4
MarginallyQualified
The home is brand new so it is very tightly built...
Does this tightly built home have an EXTERIOR fresh air intake for the hvac?
Old 02-07-2013, 06:22 PM   #5
Roofmaster
Rewards Points: 2,210
I feel for you, as I have the same type of reaction to wood smoke. There is nothing worse than someone who knows nothing about the proper way to age and burn wood. I had a neighbor that did the same thing. He loaded up his stove with unseasoned wood at night and turned the air way down. I told him he was asking for a chimney fire, and he was destroying the air quality in the whole neighborhood. He laughed, and said he has been doing it for years.
About a month later he burned about half his house down. Chimney fire got so hot it blew brick out of the chimney in the attic. The chimney looked like an afterburner on a jet fighter.
Poetic Justice.
Old 02-08-2013, 01:03 AM   #6
Rewards Points: 18
Yes, it has an exterior fresh air return system that vents into the basement. I close the vent when the smoke smell is strong outside. Still seems like more of the smell comes inside than I would think though. Not sure what other ways the smell would get in when the furnace isn't even running?
Old 02-08-2013, 01:05 AM   #7
Rewards Points: 18
Jagans,
Wow, yeah there are so many people who burn that don't burn properly. They ruin it for those who actually do burn properly. I can always tell when the neighbors use unseasoned wood.
Poetic Justice.
Old 02-09-2013, 12:28 PM   #8
Rewards Points: 77
A 1" filter will mainly keep your coil clean, carbon filters help but can only absorb it's weight in VOCs , go with a whole house filter or air purifier and run 24/7
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Install undersink filter or whole house!? Mike2181 Plumbing 7 07-19-2010 10:14 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Whole house water filter and softener gonepostal57 Plumbing 6 10-10-2008 12:40 AM
