Filter Strategy - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 07:54 AM   #1
Rewards Points: 58
Question
Filter strategy
I have a geothermal split system - heat pump in basement, air handler in attic, one central return in upstairs hallway ceiling which has about 6' of flex connecting it to the return plenum. I currently use a 1" pleated filter in the return grille. MERV 8, costs $10 for 3, changed monthly.
I understand the merits of using a 4" or 5" pleated filter. I did purchase a 5" deep one with 1" lip that will fit in my return grille. Price delivered was about $45. I've read that I should only have to change this filter every 6-12 months. What I would like to know is how I can best determine when to change the filter? Besides just looking at it, can I take pressure readings somewhere when the new filter is installed, then check again after some time has elapsed?
Overall , I want to figure out if using the 5" filter is going to be much more expensive than the 1". (I've got a dog that's been shedding straight through winter, but haven't seen any fur in the filter.) my only other option is the available slot in the air handler for a 2" deep filter.
Stickman42 is online now   Reply With Quote
Old 02-03-2016, 09:00 AM   #2
Rewards Points: 1,602
Personally I'm not a big believer in higher merv filters.
Filters were originally designed to protect the equipment and the straight old fashioned fiberglass style filters did a pretty good job at that with minimum resistance, but of course we figured why not treat the system as an air purifier too, which is primarily why the higher merv filters come into play. What people aren't aware of is that they can and most often do drop overall efficiency a little because of the increased efficiency. Particularly if you have an ecm motor which (some) will actually increase in rpm (and amperage draw), in effect costing you more money.
Pretty good article here, but to answer you question (from the article):
We also expected to see a lower pressure drop for the deeper 2-inch and 4-inch filters, because of the increased surface area and the reduced velocity of air passing through the media. Surprisingly, the 4-inch Filtrete 1550 (MERV 12) was only marginally better than the 1-inch Filtrete 1700 (also MERV 12) and the two other MERV 11 filters of the same brand (1000 and 1085).
http://www.homeenergy.org/show/article/id/667
As fir measuring devices... you need a manometer. You can get them hand held, mechanical like the one below (just an example), or electronic.
http://www.ebay.com/itm/78075-manome...4AAOSw5VFWKoZv
You can even make your own little manometer with some tubing and a bit of water filling the tube.
Bob Sanders is online now   Reply With Quote
The Following 2 Users Say Thank You to Bob Sanders For This Useful Post:
SeniorSitizen (02-03-2016), Stickman42 (02-03-2016)
Old 02-03-2016, 09:58 AM   #3
Rewards Points: 368
Don't want to hijack Stickman42's thread but in the study I found this interesting, especially I've been using a electrostatic ( not a Web ) as a pre-filter in conjunction with 1" fiberglass .
"The Web Lifetime, a electrostatic filter, was the best Hi-Merv performer. Its Merv 8 rating is surprising, given the relatively open appearance of the media compared to replaceable filters".
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 02-03-2016, 10:23 AM   #4
Rewards Points: 368
I sure hope no one falls for the e-bay manometer deal at that price. A 3 dollar rain gauge and a couple of bucks for the tubing and fitting at Ace Hardware should do it.
Old 02-03-2016, 10:53 AM   #5
Rewards Points: 58
Yeah, $55 seemed a bit high. I saw this one and thought it would be better because it could be mounted
http://www.ebay.com/itm/DWYER-INSTRU...UAAOSwoydWrC48.
Or I think I have a manometer at work I can hijack. Where in my system would be the best place to take a reading?
Old 02-03-2016, 11:18 AM   #6
Yeah, I just grabbed the first one I saw as an example. $1.25 worth of tubing and you can make your own
Old 02-03-2016, 11:23 AM   #7
Concrete & Masonry
Rewards Points: 468
I have had that exact Dwyer mounted to my chimney, tied into my wood furnace pipe, for a few years now, and can tell you that it's very easy to use and works great........
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 02-03-2016, 12:13 PM   #8
If you're talking about filter measurement then you need to place it across the filter.
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 02-03-2016, 01:12 PM   #9
Rewards Points: 368
If I read correctly, the .org test folks found it surprising the depth of the filter pleats mads little difference in air flow when testing clean filters. I have a thought for them but they would probably say " who the hell is that guy ".
Old 02-03-2016, 02:05 PM   #10
Rewards Points: 58
Could you please specify exactly how/where to accomplish this? The attached is a sketch of my equipment layout.
Old 02-03-2016, 02:51 PM   #11
Concrete & Masonry
Rewards Points: 468
That Dwyer has 2 ports on the top, Hi & Low ports. You hook one hose on the cold air return, before the filter, and the other to the trunk. I'm sure a pro can elaborate a little more, and let you know how much static pressure is acceptable..........
Old 02-03-2016, 03:43 PM   #12
An old Tradesmen
Rewards Points: 6,060
Your better off testing its actual pressure drop. Then hoping its close to that test/survey.
Old 02-03-2016, 04:25 PM   #13
Rewards Points: 58
Before the filter is open space, not in the duct system. I could see if my filter was at the air handler how I could probe it before and after. With my setup, I don't see how I can measure pressure before the filter.
Old 02-03-2016, 05:00 PM   #14
Concrete & Masonry
Rewards Points: 468
I guess you're just trying to measure "draft" then, which is how I use it on my chimney pipe. In that case, I guess you just hook to the "low" port to measure draft/restriction??
Old 02-03-2016, 07:57 PM   #15
Rewards Points: 58
So I take baseline measurements with a clean 1" and 5" filter, then check the reduction in draft later on. Sound like a reasonable plan?
Please help ID what I found in my filter! daveccarsley Plumbing 24 10-11-2015 08:09 PM
Input and output hvac Duct too small LiL-Daddy HVAC 9 07-10-2014 06:40 PM
Would you choose a DIY box fan air filter over a manufactured air purifier? Druidia General DIY Discussions 1 03-14-2014 01:41 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 06:49 PM
