Old 01-17-2010, 09:06 PM   #1
Share |
Filter Sizing - Surface Area
My 5 Ton AH, currently has a 20x25x4 filter.
It also contributes to a high WC on the return side.
I dont know how to calculate the increased surface area of going to a 20x25x5 or even a 20x25x6 filter and it if is worth the added cost...to give me a lower WC and higher CFM?
I installed this size based on the recommendation of a couple of you HVAC guys here....I think I need to go bigger.
HVAC - Airflow Issue
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-17-2010, 09:39 PM   #2
An old Tradesmen
Are you using OEM refills. Or third party refills.
3 party refills are often much more restrictive then OEM refills. .1" or more.
Old 01-17-2010, 09:54 PM   #3
I believe in the "you get what you pay for" when it comes to filters.
So I use, OEM.
Currently, I have in there 3m Filtrete filter.
When I pull it, even 1/2 the way out, I can hear a difference in the air flow through the system.
Filter Sizing - Surface Area-img_2835-medium-.jpg   Filter Sizing - Surface Area-img_2837-medium-.jpg
-Andrew
DIY hobbiest
Old 01-17-2010, 10:05 PM   #4
Honeywell 4" MERV 12 or Lennox 5" MERV 16 both measured .02" in several systems I checked.
Did you add those basement returns yet?
Old 01-17-2010, 10:22 PM   #5
Sort of, I took the end off one one of the return trunks...its a 10x26 trunk.
So, yes.
When I use my homemade manometer...I get a higher reading when I check between the blower and filter.
When I check above the filter, the reading is neglible. So I think the capacity thru the ductwork is ok.
-Andrew
DIY hobbiest
Old 01-17-2010, 10:39 PM   #6
Wouldnt I be fine with say a merv 6-8 for winter (heating) season and then bump back up to a higher merv in the summer?
I have no problems cooling the house, its heating....that is the challenge.
-Andrew
DIY hobbiest
Old 01-17-2010, 11:35 PM   #7
An old Tradesmen
3M filtrete is one of the worse you can use. they are very restrictive.
Use a Honeywell of the same MERV, and you'll get much better air flow.
You don't need more then a MERV 8.
Old 01-18-2010, 07:33 AM   #8
Good to know. My lowes only carried this filter in a 4" thick, which is what I needed baesd on your previous suggestions.
I'll order some honeywell filters today online...if I upsize to a 5" or 6" thick, that should help with the WC too, right?
Or is there a point of no value(return) when going "thicker"?
-Andrew
DIY hobbiest
Old 01-18-2010, 07:38 AM   #9
An old Tradesmen
A 5 or 6" should reduce your wc. But, I'd try one of the Honeywell 4" first.
You may not need to go bigger if you use them. And, I can't say that a 5 or 6" would have enough of a lower PD to get you a noticeable change in air flow.
A HW 4" will probably have a .1 plus lower PD across it then that Filtrete.
The Following User Says Thank You to beenthere For This Useful Post:
AndrewF (03-04-2010)
Old 01-18-2010, 01:03 PM   #10
That is a significant drop in WC, right?
I dont mind going to a 5" if it has a remote chance of being even better, especially when the filter loads up.
-Andrew
DIY hobbiest
Old 01-18-2010, 02:53 PM   #11
An old Tradesmen
A 5" will have a longer time before it restricts as much as a 4". And may be worthwhile.
That i can say from this monitor.
Old 01-18-2010, 07:52 PM   #12
What are the thoughts on a filter loading gauge?
-Andrew
DIY hobbiest
Old 01-18-2010, 09:53 PM   #13
An old Tradesmen
As often as your in your basement. Its a good thing.
Most people don't check them. But I believe you would be an exception to that rule.
Old 01-18-2010, 11:22 PM   #14
Hmmh, which way to take that remark.
I check my basement almost everyday....even though it is not a finished basement, we do store things down there...and the sump pump failed last Christmas Eve.
The way I knew the basement was flooded (4" water) was because one of my furnace monitor probes had failed, it was under water.
I saw that item on a website I was ordering the filters from. I didnt buy it...seems to me, I'd likely be replacing the filter regardless of what that device said to do.
You familar with this companies filters?
http://www.glasfloss.com/utils/file.cgi/zspf.pdf
-Andrew
DIY hobbiest
Old 01-18-2010, 11:35 PM   #15
An old Tradesmen
LOL... It was a compliment.
I use those on some commercial apps that nee good filtering, and have routine maintainence done.
The 20X25X4 HV is ok. The SB and ZL are too high of a PD. And the nice thing is with those PDs, they are rating at 500 FPM.
Furnace filter brands to avoid? MistyLee HVAC 7 11-30-2009 09:27 PM
Putting a filter in my cold air trunk? BowDown HVAC 8 09-18-2009 11:16 AM
Hot surface ignitor problems hateheater HVAC 2 01-30-2008 06:26 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 04:56 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
