Filter Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 05-13-2011, 06:53 AM   #1
Filter replacement
Is there a filter that I can use to replace the ectistatic filters without having to remove the electronic filter unit ?
Sparky1 is offline   Reply With Quote
Old 05-13-2011, 07:27 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
If it is a Lennox/Honeywell unit you can buy a 16x25x5 filter at HDepot and slide it in. There are 3 and 4 inch versions too but you may have to buy them at a heating company as they are rare. I have a 3" version that fits in skinny Trion units. You can put them in other brands but they can be loose and sloppy and air passes by them and dirt if they are not a tight fit.
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 10:45 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Hog Hair Filter mjbxx HVAC 10 04-10-2009 08:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
Furnace/Air Filter Cover bcme136 HVAC 14 09-25-2008 06:34 PM
