Filter Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 02:38 AM   #1
filter question
Hello everyone... I need some advice on filters. I recently had to replace a couple of heat pump systems at my home. When the contractor was taking out my old system he noticed the pleated filters I had been using and told me not to use them on the new system because they were too restrictive. Those were merv 11. My MAIN concern with filtration is for the "care" of the equipment. I've read that pleats were the way to go, other places say pleats, even merv 7 and 8 can be too restrictive and you should go with flat panel fiberglass filters, just make sure you change them monthly. Can anyone out there please give me the striaght poop on whats best for the system? Thanks in advance for your help with this. I appreciate your input.
Roland
ROLAND1955 is offline   Reply With Quote
Old 11-22-2008, 04:44 AM   #2
An old Tradesmen
Rewards Points: 7,328
Its your duct system that determines the quality of the air filter your system can use without ill effect.
The general pleated air filters, aren't too bad. They have sof rolling pleats.
A 3M Filtrete is one of the worst ones for being restrictive.(Sharp angled pleats)
A MERV 8 is about the lowest you should use.
Furnace/Air Filter Cover bcme136 HVAC 14 09-25-2008 06:34 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
How would you mount this furnace filter, and question about shutters to outside air uOpt HVAC 7 12-16-2007 12:01 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
